[EQUIPMENT DEPLOYMENT BRIEFING]
Welcome to X-TAC, the advanced tech tactical operations group. As a vital member of the "Vanguard Squad," you have been officially granted access to our highest-tier clearance equipment: the X-TAC Central Core — X-Chip.
This wrist-worn tactical bus delivers 24/7 high-precision monitoring of your vital biometrics and surrounding environment. No matter how high-risk your mission environment becomes, it ensures you have real-time insight into your status, allowing you to execute and complete core objectives with absolute peak efficiency.
Download X-TAC on the Garmin Connect IQ Store:
https://apps.garmin.com/zh-CN/apps/5b292053-786a-47fb-ba13-1c13fae958b8
[CORE FUNCTIONAL MODULES]
- X-Chip Bio-Core Hologram Simulation:
The core microchip is seamlessly embedded within your device. You can directly observe its dynamic holographic projection right in the center of the screen.
- 31 Tactical Data Slots:
Customize your modular data layout based on operational needs. Supports flexible assignment for 31 distinct metrics, keeping you fully informed in any combat theater:
Biometrics:
Real-time Heart Rate, Body Battery, Stress Level, Pulse Ox, Respiration Rate, and more.
Activity Metrics:
Steps, Calories Burned, Active Minutes, Distance, Weekly Intensity, and more.
Environment & Navigation:
Temperature, Altimeter, Sunrise/Sunset, Wind Speed, and more.
System Status:
Device Battery, Solar Intensity, Notification, Connection Status, and more.
- Dual Power Threshold Red Alert:
The X-Chip features independent energy-monitoring logic, allowing you to bind it freely to either "Device Battery" or "Body Battery." The moment any power metric drops below the safety threshold, the core will instantly trigger a "Red Alert Light Effect" to remind you to recharge.
- Dual-Layer Terminal Architecture (Two-Way Touch Toggle):
Long-press the virtual X-Chip hologram to instantly override authorization and dive into the second-layer Darknet Architecture for deep-dive metrics. In the secondary interface, simply long-press the "Energy Waveform" at the bottom to seamlessly jump back to the primary core control panel.
- Primary Big Number Matrix:
The center of the secondary interface is equipped with a massive digital viewport designed to lock onto the most critical indicator for your current mission, allowing you to assess the grid at a single glance.
- Real-Time Energy Waveform:
Located right below the primary digital display, this dynamic pulse wave transcribes the real-time fluctuations of your device or physiological energy. Visualizing your physical limits through data streams helps you lock down control in high-pressure scenarios and complete missions with high efficiency!
[SUPPLY LOGISTICS & AUTHORIZATION]
- 24-Hour Free Tactical Evaluation:
Upon initial deployment, you are granted a 24-hour full-access trial to stress-test the X-Chip's capabilities in the field.
- Permanent Clearance:
A one-time payment of $2.69 grants lifetime unlock for all core and secondary net features.
- Activation Protocol:
When the trial expires or when you are ready to authorize, an activation code will appear on screen. Visit the designated URL to complete payment.
(Operational Note: The authorization screen will not vanish instantly post-payment. The core terminal requires approximately 5 minutes to fully sync and sync data packets. Thank you for your patience during the encryption process!)
What’s New?
- Added New Devices Support: Expanded compatibility to fully optimize for more Garmin watch models.
- New Weather Metric: Added a "1-Hour Weather Forecast" option to the customizable data slots.
- Added 24-Hour Free Trial: New users can now enjoy a 24-hour full-feature trial period before purchasing.
- Performance Tweaks: Minor bug fixes and system optimization for better battery efficiency.
