How to uninstall a watch face
1) On your watch you MUST select a different watch face to be displayed that is NOT the one you want to uninstall.
For Garmin built in watch faces go to 5)
2) Using the Garmin Connect IQ App on your Phone / Tablet
a) Make sure your watch is connected to the Device with the App - usually your phone
b) Open the App
c) Select Device at the bottom
d) Select My Watch Faces
e) Select the watch face you want to Uninstall
f) At the top there are 3 dots, press on them
g) Press on Uninstall
h) A pop up will appear asking if you want to uninstall the watch face
I) Select Uninstall
The watch face will be Uninstalled
3) Using Garmin Express
a) Make sure your watch is connected to the Device with the App - usually using a cable to a computer
b) Open the Garmin Express software
c) Select the Watch you have connected
d) Select Apps
e) Scroll down until you find the watch face you want to uninstall
f) Select the X
g) It will come up with Removed and the X will be replaced with a download cloud
The watch face is now Uninstalled
4) Using the Connect IQ Store App on your watch
If it is not already installed on your watch it is Free to download from Garmin: apps.garmin.com/.../7cd38736-510a-4480-8801-0dfe2f5944af or search the store for Connect IQ Store
a) Open the App on your watch
b) Scroll to Installed, and select it
c) Your list of downloaded and installed (not built in) watch faces appears
d) Scroll to the one you want to uninstall, and select it
e) It will say Loading and then there is a list of options
f) Select Uninstall
g) It will ask you to confirm you want to Uninstall the watch face (showing the name of the watch face)
h) Press the button corresponding to the green tick or select the green tick
5) Using your watch - ONLY Garmin provided built in watch faces can be deleted with this method  / Delete them from the watch using the watch
a) Long press the Menu button
b) Select the watch you want to uninstall
c) If you only get the option to Apply go to 3) or 4)
d) Select Delete
The watch face will be deleted
