Application - Fenix Sleep
Fenix Sleep .. now available in the Garmin Connect IQ Store
https://apps.garmin.com/en-US/apps/9...d-f8f50417f173
Fenix Sleep for the Fenix 3, Fenix HR and Fenix Chronos ..
Fenix Sleep .. just the basics. Wait for the Green Bar, Start and Go Sleep. Sleep for those that want it easy.
Measure your SLEEP with your HR data. Simple ... see your Current HR (or time if desired via user setting), Minimum HR and Average HR value in the night.
Time display is optional with User Setting in Garmin Connect Mobile or Garmin Express.
**** Full Change Log ****
[Version 1.22] February 17 / 2017
- Added support for Fenix 5S
[Version 1.21] December 23 / 2016
- Added Minimum / Maximum detail screen .. press DOWN button to see current Minimum and Maximum values as well as the times where those values first occurred.
[Version 1.20] December 19 / 2016
- Removed auto pause feature.
[Version 1.19] December 18 / 2016
- Added back in support for the non Fenix 3 HR models. It has been tested and is now working as designed. Please let me via the Contact Developer link on the right side if you experience any issues.
[Version 1.18] December 17 / 2016
- removed user setting ... now TIME can be toggled by pressing UP (middle left) button. This is to allow easier troubleshooting of issues re Connect IQ crash experienced by a small number of users.
[Version 1.17] December 17 / 2016
- Removed support for models other than the Fenix 3 HR due to issues with Ant+ HR straps. I expect to add them back in shortly. Sorry for any inconvenience.
[Version 1.15] December 16 / 2016
- added maximum HR value to the screen as well.
[Version 1.14] December 16 / 2016
- added data logging for data retention. Configuration procedure is in the Fenix Sleep thread above.
[Version 1.13] December 16 / 2016
- added support for other Fenix models (Fenix 3 and Fenix Chronos) for use with Ant+ strap
[Initial Version] December 2016
- See your Current HR and Minimum HR and Average HR values for the night. No settings to set (other than time if desired). Just simple.
- Time available via Garmin Connect Mobile or Garmin Express via user setting. Default is Time display off.
- Summary screen to see your Minimum and Average HR values from your sleep as well as last HR Reading.
- Summary screen data is orange to avoid confusion with main screen.
    Fenix Sleep 5x has been approved by Garmin today and it is now available in the Garmin Connect IQ store.
    Edit ... Fenix Sleep 5x users, it would be appreciated if you could leave me a review. Unless it is bad .. ;)
    New Fenix Sleep / Fenix Sleep 5X versions released ..
    [Version 1.26] July 25 / 2017 -- Fenix Sleep
    [Version 1.05] July 25 / 2017 -- Fenix Sleep 5x
    - Added Pause Resume option .. it will restart the application automatically if desired if in pause mode. You have to set a time in Garmin Connect Mobile / Garmin Express as described (default is 0 seconds or disabled). This will allow you to go into pause mode and the application will resume once the set 'Pause Resume' time expires. Valid times are from 60-900 seconds (1-15 minutes).
    This is the same as the Vivoactive HR version "HR Sleep".
  • Hi, How to save the data after waking up? i only see option to resume or pause.
    Thanks
    Thanks
    You can save your data to a text file on the device by creating a text file (the same name as the .prg file) in your Garmin / Apps / Logs folder.
    Fenix Sleep 5x ... has now become Fenix Sleep 5 / 5x as it now supports both the FENIX 5 and FENIX 5x.
    VivoactiveHRGuy
    Added support for the FORERUNNER 935 as well today.
    VivoactiveHRGuy
    I own a FR935. I noticed the app after some time (I cannot say how many hours) goes in stand-by and it doesn t track the sleep anymore. thank you
    What likely is happening is that you have in your sleep put yourself into pause mode by pressing the pause button during your sleep. The application will not go into any sort of pause mode otherwise.
    What I would recommend is setting the 'Pause Time' in Garmin Connect Mobile so that the application automatically kicks you out of pause mode after a certain amount of time has elapsed. The maximum amount of time is 15 minutes or 900 seconds. The minimum amount of time is 60 seconds or 1 minute. The default is that this feature is not used unless it is set.
    That should resolve the issue you are having. This feature is available in BOTH Fenix Sleep versions .. Fenix Sleep and Fenix Sleep 5x.
    As of now .. all versions of Fenix Sleep have been removed from the Garmin store.
    VivoactiveHRGuy
  • can we still dowload in other ways?
