Fenix Sleep .. now available in the Garmin Connect IQ Store
https://apps.garmin.com/en-US/apps/9...d-f8f50417f173
Fenix Sleep for the Fenix 3, Fenix HR and Fenix Chronos ..
Fenix Sleep .. just the basics. Wait for the Green Bar, Start and Go Sleep. Sleep for those that want it easy.
Measure your SLEEP with your HR data. Simple ... see your Current HR (or time if desired via user setting), Minimum HR and Average HR value in the night.
Time display is optional with User Setting in Garmin Connect Mobile or Garmin Express.
**** Full Change Log ****
[Version 1.22] February 17 / 2017
- Added support for Fenix 5S
[Version 1.21] December 23 / 2016
- Added Minimum / Maximum detail screen .. press DOWN button to see current Minimum and Maximum values as well as the times where those values first occurred.
[Version 1.20] December 19 / 2016
- Removed auto pause feature.
[Version 1.19] December 18 / 2016
- Added back in support for the non Fenix 3 HR models. It has been tested and is now working as designed. Please let me via the Contact Developer link on the right side if you experience any issues.
[Version 1.18] December 17 / 2016
- removed user setting ... now TIME can be toggled by pressing UP (middle left) button. This is to allow easier troubleshooting of issues re Connect IQ crash experienced by a small number of users.
[Version 1.17] December 17 / 2016
- Removed support for models other than the Fenix 3 HR due to issues with Ant+ HR straps. I expect to add them back in shortly. Sorry for any inconvenience.
[Version 1.15] December 16 / 2016
- added maximum HR value to the screen as well.
[Version 1.14] December 16 / 2016
- added data logging for data retention. Configuration procedure is in the Fenix Sleep thread above.
[Version 1.13] December 16 / 2016
- added support for other Fenix models (Fenix 3 and Fenix Chronos) for use with Ant+ strap
[Initial Version] December 2016
- See your Current HR and Minimum HR and Average HR values for the night. No settings to set (other than time if desired). Just simple.
- Time available via Garmin Connect Mobile or Garmin Express via user setting. Default is Time display off.
- Summary screen to see your Minimum and Average HR values from your sleep as well as last HR Reading.
- Summary screen data is orange to avoid confusion with main screen.
