Application - HR Sleep
Now .. Your Heart and the Vivoactive HR device teams up to 'Measure your Sleep'
Get HR Sleep in the Garmin Connect IQ Store here ..
https://apps.garmin.com/en-US/apps/b...2-c9fe3f777fc0
Now measure your Sleep Performance with HR Sleep .. see how your sleep improves over time using your HR data.
Be sure that your battery is charged to at least 30% before running HR Sleep overnight. That green light .. is a little hungry.
Sleep Zones Example ..
Set Minimum Sleep HR - 40
Sleep Zone 0 .. less than 40 bpm
Sleep Zone 1 .. 40 - 43 bpm
Sleep Zone 2 .. 44 - 47 bpm
Sleep Zone 3 .. 48 - 51 bpm
Sleep Zone 4 .. 52 - 55 bpm
Sleep Zone 5 .. over 55 bpm
Thank you ..
VivoactiveHRGuy
    New HR Sleep Version released.
    [Version 1.193] August 10 / 2018
    - Added Movement by hour (0-2, 2-4 etc) data screen. This is the 8th screen in HR Sleep.
    This is just like the HR by hour screen but this one tracks your movement by 2 hour segments in the very same way.
    Remember to reset your user settings as they likely will get reset when doing an application upgrade.
    As well .. if you use data logging, you likely need to rename your text file to match the application file.
    [Version 1.199] August 15 / 2018
    - Added Movement Score and Total to Movement by Hour screen. Felt it was more important to show a Total vs Elapsed Time which is available on multiple other screens. The benefit is that you can see the numbers from the 2 screens to confirm they are in sync and the data is correct.
    [Version 1.200] August 19 / 2018
    - Changed Movement Rating on the 7th screen to values more reasonable. It is now < 150 is low, >= 150 to 300 is medium and > 300 is high.
    [Version 1.202] August 29 / 2018
    - Added percentage data to restorative / non restorative / awake screen.
    [Version 1.203] August 30 / 2018
    - Added error handling (really rounding) to percentage data on restorative / non restorative / awake screen.
    I was asked today what the 'error handling' in the last version was all about.
    It is pretty simple .. it is just there to confirm that the 3 percent numbers on the restorative / non restorative / awake screen add up to 100%. If the rounding of the numbers cause the numbers not to equal 100%, then the display will show - - - to demonstrate this result. They are really numbers with decimals but I remove the decimal part as it really is not that important in this context. It is likely only going to be for 1 second and likely in the time not that far after the application has started.
    Btw, you can have time in a category but not have a percentage value, this is cause they are decimal values and until it hits 1.00000 or greater you will still see 0. I know, I just did not want to play with the data too much. Smiles.
    [Version 1.204] Sept 02 / 2018
    - You should not see any difference.It is all in the background. Let me know if you have any issues.
    [Version 1.207] Sept 05 / 2018
    - Same as version 1.204
    Btw .. I will be adding the time when you hit the Insomnia threshold on to the screen instead of the elapsed time. Thanks to Horst for this suggestion.
    The above change .. I have completed it, I will test it tonight. If all is well .. I will release it.
    VivoactiveHRGuy
    [Version 1.208] Sept 07 / 2018
    - Added time when Insomnia threshold hit to the insomnia screen.
    - Added am / pm to time values.
    [Version 1.211] Sept 11 / 2018
    - Changed default setting to time values on summary screen.
    - Changed Fall Asleep on Insomnia Screen to Insomnia Threshold.
    - Removed totals from Insomnia screen and now display elapsed time.
    - House cleaning on Insomnia screen.
