Application - HR Tracker
Now available in the Garmin Store .. HR Tracker
*** For the Vivoactive HR ***Get it at the Garmin Connect IQ Store here ..
https://apps.garmin.com/en-US/apps/f4330b5e-cb42-4f62-a562-33cbc4d08979
See where your HR readings fall in HR Tracker.
HR Tracker has been tested with Vivoactive HR firmware version 3.30, 3.40, 3.50 ... 3.90
Note .. your maximum HR value and zone information will come from your User Profile, the one with the heart in Garmin Connect Mobile
Note .. screen shots are subject to change, see full change log below for updated details. Screen shots may be simulated to show application operation.
*** Full Change Log ***
[Version 1.135] June 7 / 2017
- Fixed a bug where the app may crash with the new Vivoactive HR firmware. It was my fault and I do apologize.
[Version 1.134] February 7 / 2017
- improved swipe screens and also operation of pause screen. You can now swipe up or down to any of the 3 screen. The pause now works as it should from all screens.
[Version 1.133] January 17 / 2017
- improved sensor handling upon exit.
[Version 1.131] December 9 / 2016
- fixed issue where rounding of numbers may cause percentages not to add up to 100% on summary screen
[Version 1.130] December 8 / 2016
- Fixed issue with exit routine. Oops .. my bad.
- Added ability to see percentages instead of times on summary screen. Set via user setting in Garmin Connect Mobile if desired.
[Version 1.124] December 7 / 2016
- added current HR, minimum HR and maximum HR display screen. This is similar to data display in HR Always.
- swipe can be down or up .. and will alternate between the zone screen and min max screen.
- removed tap to go back to previous screen .. now using back button.
Note .. you cannot swipe from pause screen just main screen. This is to prevent confusion as to what state you are in.
[Version 1.120] December 5 / 2016
- pause option with right button press on main screen. (you now cannot exit from the pause screen, you must return to the main screen to exit)
- resume (back to main screen) option with any button press from pause screen.
- added in elapsed time into summary screen
[Version 1.117] December 3 / 2016
- added marker for current zone, it will display for times up to 10 hours in a zone.
[Version 1.116] December 3 / 2016
- cosmetic changes
[Version 1.115] December 2 / 2016
- HR Tracker will now get both your zone and maximum HR values from your User Profile, the one with the Heart in Garmin Connect Mobile.
[Initial Version 1.114] December 2 / 2016
- Display of Elapsed time on right bottom of main screen with Current HR value on left bottom
- Current HR data on bottom left is color coded based on zone (Zones 0-1 Green, Zones 2-3 Orange and Zones 4-5 Red). Note .. Zone 0 is anything less than Zone 1.
- Pause / Restart option with right button press on main screen
- Heart Rate zone values (based on Maximum HR value) and Maximum HR value display via up or down swipe
- Tap on screen to return to last screen (Main or Pause screen) from Heart Rate Zone / Maximum HR value screen
- Summary screen displays summary time in each zone for your zones on exit
Thank you
VivoactiveHRGuy
    Former Member over 8 years ago
    [Version 1.136] September 2 / 2017
    - Fixed a bug where if you go off the main zone screen, the data (other than the current, minimum and maximum HR values) was not correct. This is now fixed.
    [Version 1.137] September 3 / 2017
    - Added elapsed time to Current / Minimum / Maximum screen.
    Obviously HR Tracker has been ignored. It is now a bit more like some of my other applications.
