App: Pool Swim
https://apps.garmin.com/es-ES/apps/f134a024-6ee4-47d3-8aec-3a397e3c9733
Track your pool swimming activities with your FR230 and FR235.
You can find the user guide and get support here: https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
Credits
Icon made by Freepik from www.flaticon.com
You can donate my ConnectIQ development via PayPal here: https://bit.ly/2h1EMT1
Changelog
v1.0-upd.1: bugfixes. heading might drift sometimes.
v1.0-upd.2: improve heading calculation. new multicolor icon.
v2.0: support FR630. HR data.
v3.0:Initial support stroke count (feature as beta, waiting for your feedback). Several changes in memory managment and process execution for better performance and stability.
v3.0-upd.1: fix issue. data needed for stroke count analysis was not properly written in fit file. otherwise same functionality as v3.0
v3.1: discard menu: when exiting app, now you can choose between resume/save/discard.
v3.2: display summary window when paused.
v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.
v4.0: most common pool length values and watch screen format & fields can be configured in watch. hold "up" button for three seconds. small adjustments heading. Several cosmetic changes.
v4.1:
calories can now be selected as screen field in watch menu.
new app setting "DEBUG" which enables writting of accelerometer and heading data @10Hz in FIT file (default disabled)
new feature autolap can be configured in watch menu (default disabled- when enabled, it triggers a new lap every n lengths, where n is a configuration parameter)
several bugfixes and memory enhancements.
v4.1-upd.1: bugfix calories calculation which caused crash when hr monitor is available.
v4.2: new FR630 key definition. improve how pace charts are displayed in Sport Tracks. See https://danipindado.github.io/Pool-Swim-app-v4.2-released.html
v4.3 Implement imperial units. Improve heading calibration. https://danipindado.github.io/pool-swim-app-v4-3-released.html
v4.4 Memory & stability improvements. new heading filter. stroke counting temporarily removed. https://danipindado.github.io/new-pool-swim-version-with-improved-length-detection.html
v4.5 New stroke rate algorithm. Small bugs and improvements. https://danipindado.github.io/stroke...pool-swim.html
v4.6 Garmin swim watch compatibility: recording continues during pause and stroke rate takes one arm into account only. heading chart shows now sine instead of rad. intensity field added (only 3rd party sites supporting ConnectIQ, f.i. sporttracks) https://danipindado.github.io/pool-swim-apps-improves-compatibility-with-other-swim-watches.html
v4.7 update summary window. update user guide. https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
  • Here is CIQ_LOG.TXT from my watch.
    There is another file in this catalog CIQ_LOG.BAK but I can't upload it here. I have message from garmin site "Invalid File". Do you need this file also?
    Greetings
    Thank you so much.
    Unfortunately it does not help a lot...
    Did somebody try to uninstall and install again? Is the pool length shown in the black screen correct? It might be some kind of issue with the app settings (the ones which get configured in smartphone: pool length and debug).
    Or , with the format & field configuration(watch menu holding up arrow for three seconds).
    Do all of you have a 235? I dont have the problem in my 230
  • Thank you so much.
    When I update app to 4.1 ver. in my screen appears IQ logo wiht exclamations mark.
    I restart watch but nothing changes.
    So I uninstalled app, restart watch and intall app again.
    This time I was able to see data fields but when I hold up arrow for three second IQ logo appears again.
    After a while a start app again and surprisingly I could start activity and scroll throught data fields. I can even enter configuration menu but after short while app crashed.
    Now crashes after a few seconds after starting.
  • When I update app to 4.1 ver. in my screen appears IQ logo wiht exclamations mark.
    I unistall and install app again.
    I did not enter configuration menu but I started activity immediately, add one split lap but when I stop activity crashed again.
    I start app once again and crashe after while.
    Pool lenght is shown correctly
  • I unistall and install app again.
    So weird :(
    Do you have a 235?
    And last question: have you switched of the watch?
    Ill revert it back asap.
    Former Member over 8 years ago
    I have exactly the same and I am on the 235.
  • workaround
    I have just received this from an user
    Daniel
    Maybe this can help you
    I think the problem is the hearth rate wrist monitor
    In fact I have disabled it and the app works OK
  • v4.1-upd.1
    Perfect I no longer have the worry. thank you very much
    Tested ok!
    Hello Daniel.
    Tested today latest version on FR235 on 1,5km distance against garmin swim watch.
    Simply perfect detection of lengths.
    Good job !
    ciao
    Walt
    Length detection
    Hi All
    I've been using the app for more than a month now and I had no big issues with length detection before. 1-2 pools more or less was fine for me.
    But starting from last week the app counts almost twice more distance (pool length is still 25m). I tried to update from 4.0 to 4.1, didn't help. Any advice?
    Thanks
    Vadim
