App: Pool Swim
https://apps.garmin.com/es-ES/apps/f134a024-6ee4-47d3-8aec-3a397e3c9733
Track your pool swimming activities with your FR230 and FR235.
You can find the user guide and get support here: https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
Credits
Icon made by Freepik from www.flaticon.com
You can donate my ConnectIQ development via PayPal here: https://bit.ly/2h1EMT1
Changelog
v1.0-upd.1: bugfixes. heading might drift sometimes.
v1.0-upd.2: improve heading calculation. new multicolor icon.
v2.0: support FR630. HR data.
v3.0:Initial support stroke count (feature as beta, waiting for your feedback). Several changes in memory managment and process execution for better performance and stability.
v3.0-upd.1: fix issue. data needed for stroke count analysis was not properly written in fit file. otherwise same functionality as v3.0
v3.1: discard menu: when exiting app, now you can choose between resume/save/discard.
v3.2: display summary window when paused.
v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.
v4.0: most common pool length values and watch screen format & fields can be configured in watch. hold "up" button for three seconds. small adjustments heading. Several cosmetic changes.
v4.1:
calories can now be selected as screen field in watch menu.
new app setting "DEBUG" which enables writting of accelerometer and heading data @10Hz in FIT file (default disabled)
new feature autolap can be configured in watch menu (default disabled- when enabled, it triggers a new lap every n lengths, where n is a configuration parameter)
several bugfixes and memory enhancements.
v4.1-upd.1: bugfix calories calculation which caused crash when hr monitor is available.
v4.2: new FR630 key definition. improve how pace charts are displayed in Sport Tracks. See https://danipindado.github.io/Pool-Swim-app-v4.2-released.html
v4.3 Implement imperial units. Improve heading calibration. https://danipindado.github.io/pool-swim-app-v4-3-released.html
v4.4 Memory & stability improvements. new heading filter. stroke counting temporarily removed. https://danipindado.github.io/new-pool-swim-version-with-improved-length-detection.html
v4.5 New stroke rate algorithm. Small bugs and improvements. https://danipindado.github.io/stroke...pool-swim.html
v4.6 Garmin swim watch compatibility: recording continues during pause and stroke rate takes one arm into account only. heading chart shows now sine instead of rad. intensity field added (only 3rd party sites supporting ConnectIQ, f.i. sporttracks) https://danipindado.github.io/pool-swim-apps-improves-compatibility-with-other-swim-watches.html
v4.7 update summary window. update user guide. https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
  • no data during swim
    Hello,
    thanks for the app, new to swimming and find it useful, after a couple of session also finding ti pretty accuate in terms of counting lengths etc
    I saw your post describing how the app actually works, ie looks at heading, and found this helped me make it more accurate if that makes sense!
    Did a swim the other morning though and did not have any 'live' data during a length? when i pause showed me the summary screen (in black) but while swimming if i look at the face ad the white scrren with just some dashed in it?
    wondering if i have somehow changed a setting?
    anyway many thanks again for a great app!
  • hi,
    yes , this is an issue i am looking at.
    sometimes the settings screen settings get lost.
    you can configure the screen again:
    1) start app in watch
    2) hold up arrow for three seconds to launch config menu
    3) there you can choose how many fields, and which fields, you want to be displayed in the two screens available.
    i hope this helps.
  • Total mts
    Hi
    First of all thanks for the app. Really like it. Unfortunately the total mts at the end of the training are not sync with the Garmin Connect or Phone. I need to update that manually
    Do you know if there is a bug or if there is anything I can do to get that automatically when I do the sync
    thank you
  • as i have already written in your app review :(
    this is a garmin limitation. they don't override native fields.
    But you still can find the data in GC and in smartphone app. you find that in the bottom left corner of the screen. in the "Connect IQ" region.
    as a workaround you can manually edit the distance in GC using the internet browser.
    another alternative is to sync your activities with www.sporttracks.mobi, www.trainingpeaks.com or www.runalyze.com
    unless GC, these sites do support FIT2. you will find all the data there out of the box.
  • V4.1
    Former Member over 8 years ago
    error
    :confused:
  • I don't really know how this can happen.
    Are you able to use the app at all or does it crash from the very beginning?
    It would be useful if you could send me the log files in the garmin. Plug it to your PC , the logs are in folder apps/logs
    Maybe you can delete the app and install it again....
    Sorry for this
    Hello,
    Thanks for the app that is really great and you follow the application very well and I am happy with that.
    I have the same screen break since the update in 4.1.
    I am first on the black screen then I go to the next screen and the application breaks.
    Have a good day.
    Sorry for my english, i am french
  • Hello,
    Have a good day.
    Your english is fine for me (I am spanish :) )
    Sorry for the problems.
    I will revert back the release tonight.
    In the meantime, if somebody could provide some logs, I would be ver grateful. This did not happen yesterday to me :(
  • Your english is fine for me (I am spanish :) )
    Here is CIQ_LOG.TXT from my watch.
    There is another file in this catalog CIQ_LOG.BAK but I can't upload it here. I have message from garmin site "Invalid File". Do you need this file also?
    Greetings
