Application - Step Z
Step Z now available for the VivoactiveHR
Get it here now .. https://apps.garmin.com/en-US/apps/a...3-3e3c82c5f540
Note .. screen shots are subject to change, see full change log below for updated details. Screen shots may be simulated to show application operation.
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/lh3.googleusercontent.com\/6klwd5Y2XrLlftktoIZcZoKK79dtIegxA6Vc0NrLtBH8rSKf4impNmPwiwXw0iJoctSVM8Gj1Y9-ew=w1920-h1080-no"}[/IMG2][IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/lh3.googleusercontent.com\/3egTsj1bmJUX1lyNwnZk8-tyhXmxHD17OzhXpsfFNGQfUJqY6gg02APpzTmArfkydtISZknChnm5PA=w1920-h1080-no"}[/IMG2]
Yes .. for those that just love STEPS
Watch your Steps accumulate on the VivoactiveHR
You can count a bit if you like to test things and see how your VAHR awards steps .. or just see how many steps you earn during your favorite activity.
Walk your Dog .. see your steps
Grocery Store .. see your steps
That 3 mile walk or run .. see your steps
Walk anywhere .. see your steps
A very simple app .. just for those that like cool things.
Step Z .. does NOT in any way alter your steps for the day, it is just a counter for those that love to measure things.
**** Full Change Log ****
[Version 2.74] December 2 / 2016
- no changes
[Version 2.72] October 17 / 2016
- retained existing current daily steps display in screen middle.
- added in Number of Steps until Goal is reached in screen middle. Will display message when you have passed your step goal.
- added Percentage of Step Goal in screen middle. Will display percentage over 100% when you are past your step goal.
The above 2 new display with current steps in the screen middle if selected in Garmin Connect Mobile / Garmin Express. Default is to show the 3 items in an alternating sequence.
If you do not want them to alternate, and prefer the old display method .. you can go back to the old display of just the daily steps by deselecting the "Show Step Goal / Percent Data' setting in Garmin Connect Mobile / Garmin Express.
[Version 2.59] October 6 / 2016
- fixed midnight steps count issue where the bottom number was not always correct right at midnight (and the VivoactiveHR resets daily steps to zero).
[Version 2.58] October 4 / 2016
- made normal number view the default view.
[Version 2.56] October 2 / 2016
- improved font for better readability.
- fixed number formatting issue on summary screen for steps.
[Version 2.45] October 1 / 2016
- improved exit routine. Application will now exit without summary screen if no steps are recorded.
[Version 2.25] September 29 / 2016
- added Show Hundreds Counter setting in Garmin Connect Mobile / Garmin Express to toggle 100's counter on and off (normal number view).
[Version 2.15] September 28 / 2016
- improved formatting and font size for better readability.
[Version 1.95] September 21 / 2016
- added summary screen upon exit to show you steps for up to 4 activities.
[Version 1.85] September 20 / 2016
- fixed issue at midnight where counter reset did not happen correctly.
[Version 1.75] September 19 / 2016
- font and graphical improvements etc
[Initial Version] September 19 / 2016
- displays time on top with seconds. Military (24 hour) time supported.
- shows your daily steps for the day in the middle.
- shows steps (less than 100) since reset / start on the bottom right of the screen for your activity. Reset counters to ZERO by pressing right button.
- with 100's counter on far left bottom to make everything easier if you really want to count something, though you do not have to do anything. For example .. 5 on left and 23 on right is 523 steps since reset / start.
- tap on screen to turn on / off back light. It will turn off on its own.
    New Version of Step Z for Vivoactive HR
    [Version 2.84] April 26 / 2017
    - Fixed vibration. It seems to work better now.
    [Version 2.85] June 7 / 2017
    - Fixed a bug where the app would crash in the new Vivoactive HR firmware. It is my fault and I do apologize.
    I have Step z on my vivoactive HR- records steps well but won't sync onto my computer (my vivoHR is not compatible with my phone). Syncing happens automatic with my runs and cycles- any ideas?
    StepZ does not send any data to Garmin Connect, however your steps you see in the application will be included in your daily steps that will get sent to Garmin Connect when you sync.
