Unit Converter Datafield
# UnitConverterDF
Datafield to convert between metric and statute units.
# Description
Unit Converter Datafield converts between metric and statute units. By default it is set to the "opposite of the system setting" but can be configured to metric or statute as well.
Supported measures: distance, pace, speed, elevation.
Supported units: opposite (of system settings), metric, statute (or imperial).
- unit: metric | statute
- distance: km | mi
- pace: min/km | min/mi
- speed: km/h | mph
- elevation: m | ft
## Installation
You can add it as a Connect IQ datafield to your activity layout:
1. From the watch screen enter the activity: Start/Select - choose your activity
2. Up/Menu - {activity} settings - Data Screens - choose screen - Start/Select button
3. You can change the Layout and add a new field or you can change an existing Data Field.
4. In Data Fields - Start - ConnectIQ Fields - Unit Converter
5. Exit the {activity} settings.
You can start your activity now.
## Configuration
You can change the settings in Connect IQ or Garmin Express.
On newer devices you can also change the settings on the device:
2. Up/Menu - Connect IQ Fields - Unit Converter - change measure and unit settings
## Support
If you like the DF you can thank me by sending a beer: https://paypal.me/GavrielF or buymeacoffee.com/flocsy or at least write a positive review with 5 stars StarStarStarStarStar.
## Screenshots
