Watch Face - HR Frequency
Now available in the Garmin Connect IQ store.
https://apps.garmin.com/en-US/apps/fe6a0eae-5a6b-4d62-85c2-d8b62a519b26
HR Frequency
Find out how often your Vivoactive HR gets your HR data using the Optical Heart Rate 24/7 method.
Note .. screen shots are subject to change, see full change log below for updated details. Screen shots may be simulated to show application operation.
Full Version Log ..
[Version 2.53] October 31 / 2016
- added launcher icon to take advantage of firmware 3.30
[Version 2.51] August 22/2016
- prevent HR Frequency from running longer than 24 hours.
[Version 2.50] August 13/2016
- Time (it is still a watch face .. but not really designed for day to day use). It will reset once you do a swipe or go to most other screens.
- HR Count. The number of HR readings since the program has been running.
- HR Reading. Your last valid HR reading in BPM. It will disregard invalid readings.
- Elapsed. The time the program has been running. Either in hour / min / sec or min / sec as appropriate.
- Frequency. The elapsed / HR Count .. which will give you the time between readings. I recommend letting the program run for a few hours to get the best results.
Running it overnight while you are sleeping is a great time to let it run.
- Last HR. The time when your last HR reading was taken. The data is updated on the screen when the time changes or when the Vivoactive HR detects a gesture.
- Time Start. The time when the program was started.
