Biorhythm - Widget
If you would like to share the fun of biorhythm with me, you might like the biorhythm-widget for garmin devices: https://apps.garmin.com/de-DE/apps/7fb04480-6da2-4bea-a116-8b50823e4362
This widget displays your biorhythm-stats per today. Please configure your birthday first - using Garmin Express or the Garmin Connect app
(see here: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings)!
Please note: If you update from a former version to V1.2.x, YOU NEED TO RESTART YOUR WATCH AFTER UPDATE!
New to V1.2.x:
  • Toggle display of age in days (on or off)
  • Second birthday added to supply three more pages:
- Biorhythm for a second person
- Pair analysis
- Pair harmony.
  • Additional pages can be disabled in the config-menu (if you don´t like or don´t use)
  • Additional language added: German.
For details about the theory of biorhythm, please refer to https://en.wikipedia.org/wiki/Biorhythm.
Dear Users. This Widget is free of charge. If you find biorhythm worthless, please don´t download and install it. :o
Those of you that share the fun of biorhythm understand well that the age in days in shown: It is the basis of biorhythm-calculation! How old I am in terms of years, should be known by everyone without an app, isn´t it? This is the reason why it is days.
Comments are welcome - use this thread to post them. I will try to answer them all.
Update:
There seems to be an issue with apple-devices and configuration of birthday-dates for the widget.
It seems as if Mac- and iPhone-users are not able to set the birthday in the configuration dialog for the widget.
Although I am sorry about this, I cannot test and verify this, since I have no access to apple devices (by intention though).
If you have a clue about the reason, please use the reply-function on this threads: https://forums.garmin.com/showthread.php?357472-Widget-Configuration-using-date-failing-using-Mac-iPhone
    Paarharmonie / pair harmony
    would be great to get more information on how to interpret display for pair harmony
    Pair Analysis
    The pair analysis is a display where you can see the constitution of the first person "Const.#1" in line 1 and the constitution of the second person in the line 2.
    The constitution is a calculated value from all three components Const=sqrt(Phys^2+Emo^2+Int^2) - which is basically the length of the three-dimensional vector interpretation of the biorhythm values. If all your three values are near zero, your constitution is meant to be bad, the length of the vector is small. This is because the zero line is the danger line in biorhythm whereas -100% is meant to be quite ok inside the resting-cycle of the biorhythm.
    The pair harmony is a calculation of individual cycles of person 1 and 2, taking into account special observations of mine so that this value is not only a distance vector length. There is no scientific basis for pair analysis! It is simply more fun to argue with your partner and find the explanation inside the pair harmony of biorhythm calculators.
    So: Have fun!
  • I am wondering if you can make this available for the Forerunner 745? I cannot install it from the IQ store
