Watchface: HeartBeatFace
HeartBeatFace support thread
URL: https://apps.garmin.com/en-US/apps/556c67b5-a295-48d8-9c05-72397c5dcf5e
!! PLEASE, NOTE THAT HR HISTORY IS EMPTY AFTER THE WATCH POWERCYCLE !!
You can donate the HeartBeatFace/ActiFace development via PayPal here: http://bit.ly/1RoLv4i
HeartBeatFace performs better on FR735XT and Vivoactive HR which have stronger hardware.
Now you don’t need HR widget anymore :)
Watch Face contains:
- Time and date
- HR graph for past 160 measurements (~4 hours)
- high and low HR
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
Supports 12/24 time format and km/mi.
Configuration
HeartBeatFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Custom fields types (differs between models)
- UTC
- UTC24 (always 24H format)
- steps
- distance
- calories
- goal percentage
- heart rate
- altitude
- week goal percentage (counted all step goals and steps from the beginning of the week)
- week distance average (counted from the beginning of the week without today)
- week steps average (counted from the beginning of the week without today)
- week calories average (counted from the beginning of the week without today)
- sunrise/sunset times
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
    Former Member over 9 years ago
    I have just made some fixes and workarounds when HR sensor is returning corrupted or empty data.
    I have felt HR sensor is returning data normal work
    You've worked hard
    This is a very good program
    ALEXFU
  • By the way, are you saying that the hardware from vivoactive and forefunner is stronger than the one on the fenix?
    Not in general.. Just the new FR735XT and Vivoactive HR are the latest devices and have stronger CPUs and bigger memory that "older" Fenixes and forerunners/vivoactive.
    Former Member over 8 years ago
    1.1.6 have something question
    i test 1.1.6 have something question
    problem 1
    sunrise/sunset times. i using in 1.1.2 can nornal display,but 1.1.6 also can't display
    update: i know this problem is not locate position,only full gps registering 1 record by locate.sunrise/sunset times will display.
    problem 2
    HR Graph display,if GAP to high,display may be lost
    I found that sleep time will be more. garmin widget also at the same time.
    I USE Vivoactive HR
    FW:2.70
    DISPLAY: 2.20
    CIQ 1.2.7
    No notification
    Hi,
    Is it normal that with your watch face (v. 1.1.6), I do not receive "vibrating on-screen" notifications, like emails, SMS or other iOS app notifications. The only thing I get is a small icon appearing at the top of the screen. BTW, I've got a vivoactive hr device running fw 2.71 and Connect IQ 2.1.0.
    Thanks !
  • Hi,
    Thanks !
    The vibration is firmware functionality and shouldn't be affected by CIQ watchface. I recommend to open ticket by sending mail to firmware beta team.
  • suggestion
    Hi, I'm Manuel.
    is it possible to insert the "step counter" as option in the 3 custom fields? also, is it possible to insert a 4th custom field (positioned in the bottom of the screen where the step counter is) where you can coose, for example, the HR? (in this way you'll have all the HR information near the graph)
    thanks, manuel
  • questions..
    Hi,
    I don't know if I'm using correctly your app, so I need some answers:
    -it seems to me that when push the UP or LOW button it takes many time to change the page from HBF to the other widgets
    -it seems that the HR value doesn't update correctly because when I see strange value (ex 82 bpm when I'm sure I'm around 60) and I switch to the garmin HR pages it shows the right value (in my exaple 57bpm); then, if I return to your HBF, now it shows the right 57 value... When it seems to me that the value is wrong I tryed to wait also over 30 seconds but the value doesn't change.
    please help me, manuel
    battery request
    love the watch face, will donate shortly. spent all day trying to find something useful for the Vivoactive HR. Most others are ok but not awesome. Minor request - To have the battery status as either percent only, bar only, both bar and percent (current way) or percent in bar. Thx!
    Climbed Floors
    Hi,
    is it possible to set possibility of some (better for all) fields to show clibed floors?
    Ahoj , je možné nastavit možnost nastavení polí i na hodnotu nastoupaných schodišť?
    Thank You radek
    Díky Radek
    Hello, I agree too with this request ^^
    Hi,
    Thank You radek
    Díky Radek
