EDGE All in One
IQ Store Link                                                        IQ Store Link
New device: EDGE 1050 !
EDGE All in One is a single data field.
One for Edge 1030, 1040 and 1050, the other for Edge 530 and 830, 540, 840 and Explore2
It displays many values for cycling - around the most important values: speed, cadence, heart rate and power.
A detailed description can be found here:
EDGE 1030 + 1040 (English and Deutsch and French):
mcinner.at/.../GuideAllinOne_E.pdf
mcinner.at/.../GuideAllinOne_D.pdf
http://mcinner.at/files/GuideAllinOne_F.pdf
EDGE 530, 830, 540, 840 and Explore2:
mcinner.at/.../GuideAllinOne58.pdf
This datafield is free of charge, but if you like it and use it, it would be nice to be invited to a beer: paypal.me/AndreasWirth
I have tested the datafield intensively with my devices Edge 1030 and 1030 PLUS, 1040 and 530.
Download and install EdgeAllinOne as single datafield following these steps on your device:
Activity profile - Data Screens - Add New - Custom Data - Choose single layout
In the ConnectIQ collection select EdgeAllinOne1.
After installing this datafield on your device, various settings can be made. This is best done with Garmin Express or Garmin Connect Mobile. Instructions for this can be found here:
https://forums.garmin.com/developer/connect-iq/w/wiki/14/changing-connect-iq-app-settings
To use the power section, a power meter must be connected to the device and the values of the individual power zones must be stored in the settings.
For the heartrate graphs the heartrate zones are taken from your profile. It is therefore necessary that the zones are set in your device!
For the display of wind bearing and wind force, as well as the outdoor temperature, the data of a nearby weather station must be available via Garmin Connect Mobile. The app must therefore be loaded on the phone (but it can work in the background).
If you have questions or requests please write here and tell for which device!
  • Ich weiß, welche beiden Ziffern du meinst, und es sind die Zahl der gerade aktuellen Herzfrequenz Zone (links), und die Zahl der gerade aktuellen Leistungs Zone (rechts).
    Ich versuche eine Erklärung für die linke Zahl - die Herzfrequenz Zone:
    in deinem Garmin Edge sind unter eigener Statistik, Leistungsbereich, die Zonenbereiche hinterlegt.
    Zum Beispiel:
    Zone 1: von 50 bis 70 Herzschläge pro Minute
    Zone 2: von 71 bis 90
    Zone 3: von 91 bis 120
    Zone 4: von 121 bis 150
    Zone 5: über 151
    Wenn deine Herzfrequenz gerade 126 anzeigt (linke große Ziffer), dann zeigt die fragliche kleine Zahl daneben an, dass du dich in Zone 4 befindest.
    https://support.garmin.com/de-AT/?faq=s3HqdKNtWV1NYrK16eFcc7
    Mit den Power Zonen verhält es sich analog.
    Das ist doch aus der Beschreibung zu entnehmen…?
  • Dann bitte ich vielmals um Entschuldigung.
    Dachte, ich habe mit irgendwelcher Option etwas ausgetauscht. Da auch Komma Zahlen angezeigt werden, bin ich nicht auf Zonen gekommen. „Display“ habe ich überlesen.
    Nochmals Sorry für das Nerven.
  • Dass die Zonenzahl nun mit Komma ist, liegt an vielfachen Wünschen von Usern…
  • Hallo.
    Sorry, ich schon wieder. Gibt es bei Indoor keine  Ø W  und  NP  (Noch eingefallen… Andere Profile nicht getestet)
    Bei mir steht da immer 0
    Zonen, Chart & aktueller WertThumbsup tone2
    Screenshot:
    https://www.dropbox.com/scl/fi/uq8c4t93zoiiq9an99qyu/IMG_2908.heic?rlkey=nhhrjoa2wdeydv5azg5q3ssad&st=phppcvgz&dl=0
    Danke.
  • Danke für den Screenshot (ich hätts sonst nicht geglaubt Rofl)
    Es sollte dort schon die durchschn. Leistung gezeigt werden. Obs auch NP gibt, muss ich mir ansehen, aber ich glaub schon.
    Ich schau mir das morgen an.
  • Hab das Problem gefunden: dein Bild zeigt Speed = 0, was ja Indoor vielleicht tatsächlich egal ist, aber die Berechnung von avg Power ung NP erfolgt nur in Bewegung.
    Koppel deinen Trainer auch als Speedsensor, damit irgendeine Speed gezeigt wird!
  • Geht leider nicht.
    Als Speedsensor nicht gefunden. Wenn ich ihn per Hand eintrage, zeigt er auch nichts an.
    Es werden wohl die ganzen Werte (TF, W, Speed) in einem Paket übertragen…
    Da ich mit den Vector Powermeter-Pedale fahre, um die ganzen Cycling-Dynamics-Werte zu erhalten, nutze ich nicht den Wahoo Kickr V3 als „Powermeter“
    Theoretisch könnte ich einen Speed-Sensor am Schwungrad anbringen. Wenn ich noch einen habe und das Schwungrad nicht viel  zu schnell drehtThinking
  • Hast du auch den kombinierten „Speed/Cadence“ sensor gesucht. Sollte mit dem Kickr funktionieren. Cadence kommt dann trotzdem von Powermeter.
    Wenn nicht, dann werde ich die avg. Wattanzeige von der Geschwindigkeits Abhängigkeit für Indoor lösen, weil das eigentlich nur für Outdoor nötig ist (bergabfahren, wo nicht gtreten wird).
    Gib Bescheid ob das mit Speed/Cadence funzt.
  • Hab bei kombinierten „Speed/Cadence“ Sensor gesucht und nichts gefunden. Darum, wie gesagt, da einen Sensor mit Ant+ ID per Hand eingetragen.
    Geht auch nicht. Noch die Wahoo App überprüft. ERG-Modus Geschwindigkeitssimulation ist und war ein.
    Aber auch ausgeschaltet geht’s nicht…
    Mit Bluetooth findet er den KICKR nur als Leistung.
    Hab noch eine Frage. Wie schwer ist es eine App zu schreiben. Mein Bruder wäre ein IT‘ler mit relativ guten Programmierkenntnissen in verschiedenen Sprachen.
    Suche eine App die wie   BS Dashboard   Charts zeigt. Der Programmierer hat es „geschafft“, einstellbar bis 1 Stunde, Charts zu zeigen. Speed, HR, TF und Power. Hab bis jetzt noch keine App gefunden die wenigstens Power über 30 Minuten zeigt.
    Seine App geht leider nur bis zum 1030.
  • Hab noch eine Frage. Wie schwer ist es eine App zu schreiben.
    Es ist wie alles im Leben: wenn man‘s begriffen hat, ist nix schwer…
    Wenn dein Bruder Java und C kann, wird es ihm leichtfallen, eine Garmin App zu schreiben.
    Du kannst alle Einstellung für deine Workouts lassen. Ich lad eine neue Version hoch, wo die Power Werte bei Indoor auch ohne Geschwindigkeit angezeigt werden.
