# IRunChartsField
Thread to report any issues you are having with the IRunChartsField Data Field.
Data Field with pace, hr and cadence charts for older low memory devices like Fenix 3, D2Bravo and alike: https://apps.garmin.com/en-US/apps/c48c9134-e0ce-44e5-bb23-6e0eec2db5e5
This is a free composite Data Field for the Fenix 3 watch that shows multiple values and three charts on a single field. The field is intended for old low memory devices, so not many features are supported, e.g. configurability is disabled.
IRunChartsField is open source, its code can be found on github: (will update later).
The Data Field is based on two other Data Fields. Special thanks for developers of the following ConnectIQ projects:
https://apps.garmin.com/en-US/apps/aacfc2de-b61e-40cc-a83d-52f46f9d263d
https://apps.garmin.com/en-US/apps/dc4c99a1-0886-42f5-8605-f952956e715b
## Features
* Speed: speed in km/h;
* Pace: current and average pace with a chart on the background (last two minutes data);;
* Cadence: your current cadence with a chart on the background (last two minutes data);
* HR: your current heart rate with a chart on the background (last two minutes data) and min max values;
* Distance: elapsed distance in km or miles based on system settings;
* Timer: duration of the activity in [hh:]mm:ss;
* GPS: GPS status - poor/acceptable/good signal;
* Battery: battery percentage indicator;
* Time of the day;
## Installation Instructions
A Data Field needs to be set up within the settings for a given activity (like Run)
* Long Press UP
* Settings
* Apps
* Run
* Data Screens
* Screen N
* Layout
* Select single field layout
* Field 1
* Select ConnectIQ Fields
* Select IRunChartsField
* Long Press DOWN to go back to watch face
FAQ: How to add a custom data field to an app on Fenix 3?
https://www.facebook.com/GarminFenix3/posts/441344592657118
## Usage
Start Run activity.
You should see theIRunChartsField Data Field on the app screen number selected above.
