WatchFace: Build your analog watchface
"Build your analog watchface" is designed to be hightly configurable.
You can set:
- Background color
- Foreground color 1
- Foreground color 2
- Hands style
- Hour marks display and style
- Minutes marks display Style 1/ Stile2 /off
- Indicators style Gauge (more colors) /Text
- Battery gauge display on/off
- Steps gauge display on/off
- Move gauge display on/off
- Power safe mode on/off. When Power Saving mode is active the display is updated once a minute. If you change the settings, you colud wait one minute before you see the effect.
Other characteristics:
- Seconds Hand at the gesture
- Bluetooth ("Con.") and notifications ("Msg") indicators
You are able to change the settings within the Garmin Connect Mobile or Garmin Express UI. Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings.
Instruction to remove: Before to remove this watchface, select another one on your smartwatch
  • V8
    New version 8 available
    - New configuration item to change the rectange wathface shape into semi-rounded shape (for Forerunner® 920XT, epixTm, fēnix® 3, fēnix® 3 HR, vívoactive® only)
    - New configuration options for the "3, 6, 9, 12 Style" with new font
    - New configuration options for the "Date Style" with "Date Big" (bigger font)
    - When the "Indicator Style" is Text, Move text is not displayed if the Move is zero.
  • alarm notification?
    I really like the improvements you have made to the watch face. Is it possible to add a notification when the alarm is set?
    Thank you,
  • Forerunner 735XT
    please add support for Forerunner 735XT. hopefully it isn't much work since it is the same shape as the other Forerunner watches.
    thanks!
  • Second hand randomly disappears
    Why does the second hand randomly disappear on my vivoactive? This makes it difficult to time things like beating a cake batter, for which I don't need a stopwatch but just want to look at the second hand. Other than that, I really like this watch face.
