Sportmonitor App and Datafields
Just released my App and Datafields to the Appstore. I liked to have all Information on one page.
There were some Problems in the beginning, but seems to work fine now.
App:
https://apps.garmin.com/en-US/apps/f6cf3247-778d-4876-ab12-d6c33b870dea
Datafield One:
https://apps.garmin.com/en-US/apps/94b47f4d-f22a-4c91-bc95-9b213d9dee1f
Datafield HRbar:
https://apps.garmin.com/en-US/apps/752635f6-72c8-40e5-9281-2231928b2ee2
    Former Member over 8 years ago
    Nice App!
    App:
    Datafield One:
    Datafield HRbar:
    Please explain what the "1.0 TE" in the lower right corner field stands for.
    Thanks.
  • Thanks!
    That is the Trainingeffect. That value is from 1to5, you can see it in Connect also.
    https://www.firstbeat.com/en/consumer-products/features/#training-effect
    Really nice!
    Thanks!
    And what about the data respectively on the left and right of the upper big clock time? Left seems to be the app timer but with some difference from the lower one.
    Thanks
    i like, but ... can you make a app variant with pace and avrg pace on (speed / avg speed) , and in actsteps put Calories?
    Thanks alot.
  • i like, but ... can you make a app variant with pace and avrg pace on (speed / avg speed) , and in actsteps put Calories?
    Thanks alot.
    Thanks!
    The Beta Version already has it :-)
    There are two new pages, one for Running (Speed/Pace configurable) and one for BIking with bigger Speed Value and cadence.
    It will take some more days, some minor improvemnts have to be done and I want to test it a lot before releasing it.
    Thanks
    I mean, what are the fields (colored in yellow in the above image) indicating?
    The first looks like a timer, but differs from the other one few seconds.
    Thanks!
  • I think i have to add some describing picture to the appstore...
    The two fields are the time in Lap (resets if you push the Lap button) and the Heartrate zone.
    The timer on the bottom is the time in currect recodring (since you pushed start)
    missing information for the last sport widget
    I have noticed that when using your app (used only for walking and hiking so far), once you have chosen the activity, the activity is correctly stored and filed into the Garmin Connect database (as a walk or a hike), but the "last sport" widget misses such information and the corresponding icon (in the case of walk or hike a green walking man icon and a green circle all around the display, in the Fenix3HR).
    Is it normal or does it need to be fixed?
    Many thanks!
  • I have noticed that when using your app (used only for walking and hiking so far), once you have chosen the activity, the activity is correctly stored and filed into the Garmin Connect database (as a walk or a hike), but the "last sport" widget misses such information and the corresponding icon (in the case of walk or hike a green walking man icon and a green circle all around the display, in the Fenix3HR).
    Thanks for your reply, I will check that!
    the datafield is fantastic
    I tried also the datafield (the HR one) for walking or hiking and it is FANTASTIC!!!
    Just two questions:
    - would it be possible to put the heading (compass or GPS compensated) somewhere?
    - would it be possible to use the same colors as HR widget does (light gray - dark gray - light blue - green - orange - red)?
    Thank you!
