Watchface: Instinct EDC
My motivation for creating this watchface is: Simple tidy watchface with everyday progress info only coming from the watch itself.
Of course time (date) has the main focus. Being a bit older digital numbers (even in THAI_HOT font) are not always readable without glasses, so I took the opportunity to create a small analog watchface in the subwindow. And believe me: although being small, even without glasses it is very good readable,
After 2 hernia operations I really have to keep track of sufficient and regular daily walks etc. So the the second focus of this watchface is about daily movement. Big but very important: the move bar. And of course the daily steps and active minutes. Both with very subtle progress lines. To keep track on not overdoing things: a heart rate graph and body battery indicator.
I did't want to show info you would only view once a day or (for me) is not very relevant. So: no weatherdata because weather-apps on your phone are much nicer and better, no sun rise/set  times because for me it is not very relevant (and it gives a very precise number for a very fuzzy event), no height or stairs info because I live in a very flat country.
The thing I always liked in a watch but only a few "real" watches have is a moonface indicator. So I added one, just for fun.
Other small indicators are an alarms indicator and a notification indicator (the only indicator which would require a connection with your phone).
For solar devices there is an indicator showing solar intensity > 20% (so the watch is charging). It is visible instead of the moonface, because the moon won't be visible when the sun is shining ....
As an extra I added the current (internal) temperature, but I'm not sure if this will stay, I probably will make some fields user-adjustable.
Please give your comments!
