Edge 1040 + Varia 715 configuration/filters not working
Hello all.
I'd like the radar light to turn on when the timer is active and a vehicle is approaching. Unfortunately, this does not work with my following configuration.
2,1!Radar:2I]0]0H]2#0,73413136#1,1!:1:7:0:0D=1#0,73535488#1,1!:1:7:0:0D=1#7,6:Varia 800!2,:-1,Off:0!1,High:2!1,Medium:3!1,Low:4!1,Night Flash:6!1,Day Flash:7#6,5:Varia 715!2,:-1,Off:0!1,Solid:4!1,Peloton:5!1,Day Flash:7!1,Night Flash:6#0::#0:0#123!:123!#B3843#4#11#0#0
The latest 1040 v12.15 and CIQ is installed. The Edge is set up as described (Light Beam Activated). Via the data screen I can switch the lights manually, but unfortunately the radar does not start to flash in smart mode with the filters set up.
What is wrong here? Btw. must the front light also be on?
Thanks
Patric
