Single Data Fields
Hi,
is it possible to use the small single data fields just to turn the lights on/off and adjust the settings in the widget? It is a bit tedious that I have to press through all the different settings (N/M/S) in order to switch the light off (and that even during a ride). If this is not possible, can I at least deactivate mode N and S?
Thanks, Christoph
