Add a '0' in front of the Custom time zone when set to UTC
Your watch face it excellent, I really like the fact that the choice of data you can display in the various fields is far greater than the limited choice you get with some of the Garmin faces.
Could I ask if it's possible to add a leading '0' in front of the Custom Time, especially when it is set to UTC, please? Although Garmin seem to think there is such a thing as 'Military Time' in the General watch settings, where the time is always displayed as four digits before 12:00, having spent a long time in the military, this is news to me! They also miss out the ':' in the Military Time display, which in my experience is not what is done. I now work in commercial aviation, where all time is referenced to UTC (or 'Zulu' time as we call it) and the correct way to display UTC time is to always use four digits, and a colon, so times before 12:00 should have a leading 'zero' (for example 7:23 am, should be displayed as '07:23' in UTC)
Many thanks
  • Some apps/watch faces have a "contact the developer" link on the store site or, as a minimum, a specific thread.  You have posted on the main layer of the Showcase Forum with no reference to the watch face you are asking about so it is much less likely that you will get any response.  As a minimum I would suggest added the name in the title but even more likely to get a response by checking if there is a support link or a thread for the specific  watch face.
    Side note - from my military experience, military time does not use a ":" (unless I'm misreading what you say here).
