Widget: Temperature
Overview
https://apps.garmin.com/en-US/apps/0398a4db-a4ee-49f4-aca3-e380b93dba45
This Temperature widget shows the current (approximate) external temperature using the built-in sensor, along with a thermometer showing the degrees. It will show 'AIR TEMPERATURE' when not worn on the wrist (leave it off of the wrist for ~10-15 minutes to get a somewhat accurate reading), and 'SKIN TEMPERATURE' when worn on the wrist. Core temperature is an estimation using the skin temperature reading. A graph is also available showing the data for the last X hours (depends on device size).
Features
  • Current temperature of the air, or of a surface
  • Beautiful history graph
  • See a history graph of the estimated core temperature
  • Estimated core body temperature (when worn on wrist)
  • On-device setting adjustment from main screen (open Menu)
  • Supports 30+ languages
Settings
  • Configure unit of measurement
  • Set core body temperature degrees adjustment
  • Toggle haptic feedback via vibrations
  • Toggle screen transitions
  • Graph estimated core temperature history
  • Toggle history graph normalization
  • See the current unlock status
This thread is to discuss problems with the widget and also possible future functionality.
Thanks!
Kyle
