Widget: Compass
Overview
https://apps.garmin.com/en-US/apps/184d806a-e425-403e-b142-9d63e0abaf14
This widget shows the current degree heading along with altitude and barometric pressure trend, the altitude history, barometer history, current Lat/Long location along with GPS signal strength (blue means it is using the last known GPS location), and a dedicated compass screen for doing deviation.
The screen showing degrees and N.E.S.W. letters below degrees allows for Deviation. For touchscreen devices tap on the screen, and for devices with 5 buttons press the Start button, to enter/exit deviation mode.
Settings exist for fine-tuning the experience including adjusting for declination.
Features
  • Current heading in degrees
  • Current altitude
  • Barometric trend
  • Beautiful history graphs for elevation and barometric pressure
  • Calculate deviation degrees
  • See current coordinates in multiple formats along with GPS strength
  • View ambient (local) pressure on barometric graph screen (open Menu)
  • On-device setting adjustment from main screen (open Menu)
  • Supports 30+ languages
Settings
  • Toggle the showing of altitude unit of Measurement
  • Altitude Unit of Measurement
  • Barometric Pressure Unit of Measurement
  • Coordinates format
  • Set degree declination (adjustment)
  • Adjust refresh rate
  • Customize the compass color
  • Toggle haptic feedback via vibrations
  • Toggle screen transitions
  • Toggle history graph normalization
  • See the current unlock status
This thread is to discuss problems with the widget and also possible future functionality.
Thanks!
Kyle
