Overview
https://apps.garmin.com/en-US/apps/7b673a6e-bda7-4711-87a3-0f1dad28db09
This widget shows the current (Mean Sea Level) barometric pressure using the built-in barometer sensor, along with a gauge. A historical trend is shown via an arrow below the gauge. Arrow indicates falling, rising, or steady, pressure conditions. A graph is also available showing the data for the last X hours (depends on device size). The third screen will show the current local (ambient) pressure.
There is also a 'Pressure Dropping' feature that will alert you if the pressure is dropping by an amount that is greater than specified in the Settings (see Settings, off by default).
You can also change most of the settings from the device Menu (device dependent).
Features
- Barometric Trend
- Gauge
- Beautiful history graph
- View Pressure Dropping rate-of-change (open Menu on graph screen)
- Alert for pressure drops
- On-device setting adjustment from main screen (open Menu)
- Supports 30+ languages
Settings
- Unit of Measurement
- Toggle Storm Alert
- Set Pressure Dropping alert rate-of-change
- Set Pressure Dropping alert text
- Toggle haptic feedback via vibrations
- Toggle screen transitions
- Toggle history graph normalization
- See the current unlock status
This thread is to discuss problems with the widget and also possible future functionality.
Thanks!
Kyle
