change distance to metric?
Hello!  How do you change the distance covered in a day to metric?  I'm sure this is easy but I'm completely stumped.  I have a Vivoactive 3.
Thanks!
  • I'm assuming you are asking about a specific app or data field but you have posted in the top level of this forum with no indication of which app.  i would suggest you check to see if the app/data field has a "contact the developer" link, a specific sub forum thread for support or, as a minimum, include the app/data field in the subject.  Hope this helps you get a response.
  • On the device itself, under settings>system> units, set distance units.
