I have tried recalculating my gps but continue to get altitudes that are around 200-300' lower in elevation than I'm actually at. Weather and other data seems to work fine.
do you know if this app/watchface uses barometric altimeter or gps altitude? i believe the va3 music has a built in barometer which means it can use pressure to calculate altitude, however this is not as accurate as gps altitude. pressure altitude is a data point more useful for aircraft pilots and mountain climbers.
