Data Field: AppBuilder Temperature calibration
Sorry to ask the question again but I'm hoping that there might be an update.
Is it possible to call  and update Temperature or Tempe (if you have that device installed) with a calibration value?
Both internal and external (Tempe) temperature readings with my Edge 1030 Plus are too wrong to ignore as others have found.
I was hoping to use the Data Field: AppBuilder to do the simple math to calibrate them.
I have tried Temperature - 8   and Tempe - 4.2 and received  ' !Name' on my 1030+ display which I'm guessing is an error message.
I can get data with Altitude / 2 for example.  I have tried both Temperature and temperature cases as well.
What am I missing?
BTW, I am seeing more responsive temperature readings with the Tempe zip tied under the 1030+ front mount.
Maybe better air flow than under the seat?
