Dr Skiba W' Bal Complex DataField
Hi,
if you are interested Dr Skiba W' Balc Complex DataField is available:
https://apps.garmin.com/en-US/apps/d1561ff8-0938-4b6b-8c77-1c4ea6215dd7
I accept any comments.
Thanks
  • Hi,
    They have detected that the DataField reestar the garmin with autopause is enable. I'm on it.
    Thanks
  • I have tried the app.
    I am unable to save my CP (there is a typo and PC is displayed) and W' on the device. Garmin express and garmin android app have the same result.
    Still used it and believe it has the potential to be absolutely brilliant, TTE and TTR are interesting but would like an option to use as a simple data field with only % displaying. The primary use would be to better attack in races and would like to be able to take a quick glance and see a big number in the middle of all the other data fields (when 10 are displayed).
    Thank you.
  • i have the same issue as mentioned above: the CP (typo PC) and W' not saved on the Edge 1K through GExpress (it's showing that ok, saved, but nothing changed on the device itself). I tried to set it with GCM (Android, 3.4.1.1), but i got an error message (an error has occured) when i want to go in the app's settings menu, and nothing happens
    btw, i tried an another similar app (W' Prime), and there r the same issues so i think the problem is at the Garmin's side (in Express and GCM also)
    Br,
    Luko
  • Thanks, I look to see if I can find solution
  • Hi,
    Launched v1.1 versión:
    + Autopause garmin reestart fix
    + Layout centered with correct Font size
    + Add min W' Bal
    + CP and W' configuration fix
    Thanks
    Thank you.
    ok, monday you have it ;)
  • After a serious struggle, and several tries the edge eventually saved my values in the data field settings (CP=300W, w'bal=26000J)
    Did a small hill climb timetrial today, and although the values had been saved w'bal percentage availability was way off. I finished with around -100% or something.
    Here's the graph from GC for W' expended in the race:
    Lowest value was 3000 J, give or take.
    Thank you
    Thank you
    Hi,
    Thanks for reporting, in the last versión (1.1) i have introduced a stupid code error, sorry!
    I can confirm whether it is the version with which you made the race?
    Thanks
  • Yes, it was version 1.1
    Ride available here:
    https://www.strava.com/activities/515719477
    Fit file here (if useful)
    But 291W average, 298NP. A few anaerobic bits but not too much. With around 300W CP
  • I'm still unable to save my CP and W' on Edge 1K, neither with Express (It shows it's ok, reopening the setting shows the right value too but on the Edge 1K there is the default 380/19600 values) and neither with GCM (still has error message in settings). How did You do that?
