WatchApp: Triathlon, Duathlon & Aquathlon
by Mobilendo: http://mobilendo.com
Thanks to www.pmprog.co.uk for the code.
"Triathlon, Duathlon & Aquathlon" is a multi-sport app for triathlons, duathlons and aquathlons. Designed to record a swim, a cycle and a run in a triathlon.
Usage:
-Press the "menu" button to enter the menu, where you can select if you want to do a Triathlon, Duathlon or Aquathlon and configure the Run Settings. You can select whether or not to use the auto lap, set the auto lap distance and select the kind of pace to view (current, average or lap pace). It is posible to configure al this features with Garmin Mobile and Garmin Express as well.
-Once started, the GPS will try and connect, the red bar above and below the phase chevrons indicates GPS signal, and will turn yellow or green when a signal is acquired.
-To start your triathlon, press the "Enter" button. Press "lap" button at the start and end of each discipline.
-Press the "lap" button a final time at the end of your triathlon or duathlon, and you will be presented on-screen with the total time, with phase split times.
IT SUPPORTS HEART RATE
Change log:
-2.0: Run Settings added. You can select whether or not to use the auto lap, set the auto lap distance and select the kind of pace to view (current, average or lap pace). It is posible to configure al this features with Garmin Mobile and Garmin Express as well.
-1.0.2: Menu changed
-1.0.1: Supports changing mode from Garmin Mobile and Garmin Express
Download Link:
https://apps.garmin.com/es-ES/apps/6dccea1a-8d3e-4be8-93c2-466588ff803c
  • Does this support transitions?
    It doesn't save the transition FIT file into the watch, so the transition time is not uploaded to garmin connect. It is due to problems with the processor of the watch.
    Não consigo sair da aplicação.
    Boa noite.
    Eu não consigo sair na aplicação.
    Tenho o Forerunner 230 e ao clicar na opção "exit" e em seguida em "Sim" a aplicação não executa?
    O sistema retorna para a tela inicial.
    Como faço para sair e retornar às funções padrões do relógio?
    needs more
    Ability to discard data. Ability to quit part way thorough
  • Font too small
    Great app to use during my triathlons on my F235. Problem is that I can't see the details when I'm competing in the triathlon, it's just too small font.
    Are you considering alternative screens that you can change during the discipline? Suggestion, drop the Pace & HR, and increase the font for the other values. Change screens with the Up and Down buttons.
    Thanks!
  • It doesn't save the transition FIT file into the watch, so the transition time is not uploaded to garmin connect. It is due to problems with the processor of the watch.
    Could the time of day be used to calculate transitions for the files afterwards and to create a new file manually that is then uploaded to Garmin?
    Indoors
    Hi there
    Does this app work indoors on a trainer and treadmill without GPS?
    Regards
    Ross
    4th discipline?
    I really like this app and use it all the time. Another app I found includes a Bike/Run discipline. This is great for brick workouts. Can a 4th one be added to do this?
    Hi Lucamrode and thanks for your great app!
    Regarding transition time, maybe it could be included in the previous activity in garmin connect, as a lap?
    I mean, once the triathlon activity will be synced to Garmin Connect, report could be like this:
    - Swim activity: 2 laps. 1st lap is the Swimming activity during competition. 2nd laps will be the 1st transition time
    - Bike: 2 laps. 1st lap is the Biking activity. 2nd laps will be the 2nd transition time
    - Running
    Also, is it possible to add, for biking, the RPM support? Or if not enough space, to chose between the HR and RPM?
    Thanks again for your app!
