hrTSS DataField
Hi,
if you are interested hrTSS data field is available:
https://apps.garmin.com/en-US/apps/76071844-e7b2-47a7-a3e6-6908f2e2db55
I accept any comments.
Thanks
  • Hello MattinG!
    This might be the perfect TSS helper for me. I work as bicycle messenger and don't have a power meter on my work bike. So this could be a great help, This might even be of some use when I consider that I not only ride my bike as efforts, but also for example run stairs and things like that...and that might help getting a better TSS for my working days.
    I did a test today and instantly did a mistake: I didnt write down the HrTSS when ending the activity and I think the value is now "lost", right?
    So that would be a question if there is a way to store the HrTSS in the fit file to get it over to Garmin Connect or even better into Golden Cheetah when opening the fit file there. If including it as a metric right into the fit file is not possible, then maybe there could be a trick like using another datafield for the purpose. Like a description field (I dont know what is actually avaiable in a fit file as these are binary coded)...
    Thank you for your effort and thank you for sharing!
    Rodja
    (Edge 520)
  • Hello MattinG!
    Rodja
    (Edge 520)
    Hi Rodja,
    ConnectIQ does not currently allow us to record to the FIT file.
    I have plans to add a change to display hrTSS when save de ride.
    Thanks
  • ...great!
    How about adding a threshold value expressed as a minimum heart rate in order to count any TSS points? That way a longer pause won't have a big impact on the TSS. I mentioned that I work as bicycle messenger and it happens that I stand by for upto 30 minutes where I just sit or stand and wait for a job and then the TSS increments 0,01 every second which means 36 TSS per hour just by doing nothing.
    Take care,
    Rodja.
  • ...great!
    Take care,
    Rodja.
    ok, Thanks for the input
  • Hi,
    I updated the App to 2.0:
    + hrTSS not calculating when is stoped/paused
    + hrTSS value is recorded in datalfield until start the new ride
    Thanks
  • Not sure what I did wrong. I added this data field to my custom HIIT app. As soon as I started my workout the data field showed a blue I with a yellow exclamation point. It never showed a value. I did input a threshold heart rate before I started.
    You can send me the files in "Garmin/Apps/LOGS" to [email][email protected][/email]
    Thanks
    Thanks for this data field. Now I can input the hrTSS to my worksheet. May I know how you compute for the hrtss?
  • hrTSS Data Field Issue
    I'm also experiencing the same issues as above. On Edge 520, I'm just seeing the blue IQ logo with yellow exclamation circle. This had worked for some time with no problem! But I'm not exactly sure what might have changed that I'm now receiving this error, if it was a firmware update to 520 or something else. I have inputted a threshold HR through Garmin Express, but still does not seem to work. May I email you the log file? Thanks!!
