Data Field: Race Pacer
A forum to support and discuss the "Race Pacer" data field.
  • How to Make Race Pacer Full Screen?
    Hello,
    Just downloaded app for VAHR.
    How do I make it so it is FULL screen?
    Currently all the data is squeezed into only 1 data field?
    Thanks,
    Dale
  • Hello,
    Thanks,
    Dale
    You need to configure your datascreens for your activity and set it to 1 data field for the whole screen, i think for vahr it is under app settings . You may have to check your manual.
    Cheers
  • You need to configure your data screens for your activity and set it to 1 data field for the whole screen, i think for vahr it is under app settings . You may have to check your manual.
    Cheers
    The va-hr only has 2 and 3 data field layouts. You can't make it full screen on a va-hr. You start an activity, then press "menu" (long press right button), then tap "Run Settings", then tap "data screens", then tap to select a screen, then tap "layout".
    Best you can do is 1/2 screen.
  • Hello,
    Thanks,
    Dale
    Having just googled, seems for va you need firmware version 3.5 with iq connect v1.2.6 to support single data field screens. So you may need to update firmware and find out how to get to the settings...
  • Having just googled, seems for va you need firmware version 3.5 with iq connect v1.2.6 to support single data field screens. So you may need to update firmware and find out how to get to the settings...
    The va and va-hr are different devices and have different screens and layouts (the va-hr is the va screen turned 90 degrees)
  • The va and va-hr are different devices and have different screens and layouts (the va-hr is the va screen turned 90 degrees)
    Thanks Jim, glad someone knows...!
    Cheers
    Former Member over 9 years ago
    Hi Anna, it seems to work fine on my UK fr235, with firmware v4.60. can you describe what happens please? Error or bad screen format or..?
    It seems the Chinese watches are somewhat behind on firmware, wondering if that is causing the problem? Is 4.20 the latest available?
    Yes, Chinese watches are somewhat behind on firmware -_-!! 4.2 is the latest available right now. Just updated it last month. It didn't show any error message just told me to remove exsisting IQ datafield(already set it at row 1) before I can set one(at row 2). So, I can't set Race Pacer twice. Thank you!
  • Yes, Chinese watches are somewhat behind on firmware -_-!! 4.2 is the latest available right now. Just updated it last month. It didn't show any error message just told me to remove exsisting IQ datafield(already set it at row 1) before I can set one(at row 2). So, I can't set Race Pacer twice. Thank you!
    Can you check you haven't already got 2 data fields selected for your activity settings, as you can only set a maximum of 2 data fields. When you try and select the 2nd Race Pacer from datascreens does it say 2/2 IQ Connect apps set already? If so you need to check you haven't got another data field set elsewhere or on another screen?
    Former Member over 8 years ago
    Ah I see. It's my bad. I did set another datafield on the second screen......:o THANK YOU very much for solving my problem "everytime"!! *grins*
    I use this app on a vivoactive hr and it's works great.
    But the font for numbers and text is too small for me. I couldn't read anything.
    If I look to the photo of the fr235 it seams that a larger font is used.
    1. Topic "font size to small"
    Please could you increase the fort and change the style to bold?
    To increase the space in the bottom line you may remove the Grade.
    (But this is only my personal opinion)
    2. Topic "Bug when using 3 data-lines"
    Display with 2 data-lines:
    Line1: Pacer Req.
    Line2: DstR Grade Est.
    Display with 3 data-lines:
    Line1: DstR Grade Est.
    Why I got the same information if I choose 3 data-lines?
    I miss Pacer and Req. if I use 3 data-lines.
    3. Topic "move content one line below"
    I only can see the second half of the first line
    Line1: A: 120 D: 0
    Line2: 9.5 km in 53
    P: 5:34 -> 5:34
    I only can see the second half of Line 1
