Hi
How does it works on VA?
Which data are avaiable?
It's possible see Pacer and estimate on the same field? Do you have a screen shot of VA?
Thanks
@AnnaTseng
Please see the updated description explaining the "multi-field" layout screens, where it displays certain values when placed in certain fields of the layout. The idea being here so you can combine "Race Pacer" with other standard Garmin fields, eg.Heart Rate...
HI!THANK you for the detailed instruction. I updated it to 1.17 version yesterday and tried several times, but failed again (>_<!!)
Here is the screen shot of my fr 235, (View it directly online : http://imgur.com/VCCXZCz ) maybe you could be able to know what I did wrong or missed some critical part. As you can see from the pic that even tho I set up RACE PACER twice with both row 1& row 2, only PACER +/- value showed up but none of others. And if I set the data screen as Fullscreen field, it doesn't show all values either, but just PACER +/- value at the middle of the screen. It's very frustrating, pls help!…THANK YOU VERY MUCH.
P.S. Could it be the language problem? I am using Traditional Chinese.
Also, please make sure your watch firmware version is up to date...
