WatchFace: Digic Watch
https://apps.garmin.com/en-US/apps/d021d6e7-22d3-49e3-a626-4f687f6d1ddd
Settings Features (https://forums.garmin.com/showthread.php?332843-How-to-App-Settings):
- Layout: activity, sunrise/sunset, data;
- Time in UTC setting, shows main time and date in UTC if turned on;
- Background color (black/white), label color, value color, time color;
- Row 1 fields: month, date, day;
- Row 2-4 fields: phone (bluetooth), battery, alarm, notifications (msg), distance (m, km, ft, mi), steps, steps goal, calories (kCal), latitude, longitude, altitude (m, km, ft, mi), training effect, sunrise, sunset, move bar, seconds, UTC time, local time, time till next sun event (sunrise/sunset), week number;
- Activity layout: distance, steps and calories, steps graph for last 7 days and today (left to right);
- Sunrise/sunset layout: sunrise and sunset time on the timeline based on latest position available. Use "Row 4: Middle Field" to change field below the bar;
- Data layout: 4 rows of fields;
IMPORTANT: latitude, longitude, altitude and training effect values are based on last activity, hence please turn GPS on until green status.
Feel free to join the discussion: https://forums.garmin.com/showthread.php?340009-WatchFace-Digic-Watch&p=784765
FB: https://www.facebook.com/yurkevich.vladimir
Thanks for using it! Please don't forget to leave review.
Changelog:
v.2.0.0:
- Added support of Forerunner® 230, Forerunner® 235, Forerunner® 630, Forerunner® 920XT, ForeAthlete® 235J, ForeAthlete® 920XTJ, epix™, vívoactive®, with either 3 or 4 rows fixed layout that fits the screen
v.1.1.22:
- ISO week number field added: https://en.wikipedia.org/wiki/ISO_week_date
v.1.1.21:
- Fixed issue with 12:00 AM hours.
v.1.1.20:
- Very bottom field in Sunrise/sunset layout is now using new "Row 4: Middle Field" to not interfere with already set up layouts, please use it;
v.1.1.19:
- Fields added: UTC time, local time, time till next sun event (sunrise/sunset);
- Very bottom field in Sunrise/sunset layout is now configurable and using "Row 4: Left Field";
- "Time in UTC" setting added, shows main time and date in UTC if turned on;
v.1.1.18:
- fēnix™ 3 HR support added
v.1.1.17:
- Settings issue fix
v.1.1.16:
- Max speed field removed because it doesn't have any data on watch faces.
- Fields added: move bar, seconds, time zone, altitude (km, ft, mi)
v.1.1.15:
- Distance kilometers and miles fix
- Settings fixes
v.1.1.3:
- IQ SDK v.1.2.3
- Data layout added (4 rows)
- New fields added: distance (kilometers), distance (feet), distance (miles), steps goal, latitude, longitude, altitude (meters), max speed (km/h), training effect, sunrise, sunset
v.1.1.1:
- Added background color (black/white) setting
v.1.1.0:
- Bluetooth renamed to Phone, hence Battery is back again to the middle by default
- Notifications setting removed
- Layouts added: activity history (default) and sunrise/sunset (BETA)
- Sunrise/sunset layout (BETA): shows sunrise and sunset time on the timeline based on latest position available, time till sunrise/sunset and current time on the timeline.
- Fields settings added. Row 1 fields: month, date, day. Row 2 fields: phone (bluetooth), battery, alarm, notifications (msg)
v.1.0.5:
- Mobile devices settings issue resolved
v.1.0.4:
- Settings added: label color, value color, time color, show/hide notifications
v.1.0.3:
- Language fixes
v.1.0.1:
- Small fonts refinements
- Attempt to fix missing characters on other languages
v.1.0.0:
- Main release
Discussion. Suggestions? Bugs?
    It seems like you need to delete installed Digic Watch before.
    Tried, failed with the same error, settings file is not getting deleted but *.prg disapears...
  • It seems like you need to delete installed Digic Watch before.
    If you built with a 1.2.x SDK and the watch has a 2.1.0 or 1.3.0 VM, you'll get the signature error on a side-load and the .prg will be deleted.
    See:
    https://forums.garmin.com/showthread.php?354407-App-Signing-and-Security&p=865447#post865447
  • The watchface on Fenix 3 and it's great but I've noticed a 3-5 sec delay every time i use a button and exit the watch face (switch between widgets, goto settings, etc).
    Do you already know this issue? Is there any update for it?
    Can I provide you with polish translations? Are you able to put them in?
    Hello, I love the watchface, definitely the best one out there. I have a question though, is there a reason that you did not include seconds on the regular time? I understand its available as a field, but it lags behind and catches up every once in awhile. Can this be added? Some of us military folks rely on seconds daily in our jobs and the field is not easy to spot in a hurry nor is it as accurate.
    Also, is can you add text color changes for the different fields? Like if i wanted UTC to be red or dark grey so it stood out more? Thanks for the awesome product!
    Hi. I have a problem, cause when i try in install the app, it says that my "{0}" needs to be updated. I guess the {0} = watch, but my watch is updated. It is a vivoactive. Do you have a solution ?
    Не удается установить
    Владимир, добрый вечер.
    Очень понравился ваш дизайн, но к сожалению не удается установить.
    ConnectIQ при попытки скачать пишет "Для данного приложения требуется обновление устройства fenix 3. Воспользуйтесь Garmin Express, чтобы обновить устройство fenix 3."
    Я проверил обновления "You're up to date! Software Version: 7.20" но увы!
    Подскажите пожалуйста в чем может проблема.
    Спасибо.
  • 12/24
    how to switch on 24 hour, not AM/PM? my model is forerunner 230. thank you for great face
    On your watch, go to menu > settings > system > clock > time format, and select 24 hour.
  • On your watch, go to menu > settings > system > clock > time format, and select 24 hour.
    thank you very much
  • I'm seeing the same problem as in this post. The activity bars show up as FRI SAT SUN MON TUE SUN WED THU. Note the extra Sunday between Tuesday and Wednesday.
    Additionally, on my fr920xt, I can't get it to display any of the graph options for the 3rd or 4th row. If this is expected behavior, you should be able to create device-specific property definitions that disable those options when configuring the watch face for a given device family. i.e., you can make a resources-fr920xt folder with a customized set of resources. If the Activity History, Sunrise/Sunset, and Calendar options are not supported for that device, you could just eliminate the Layout property entirely. Additionally, since it doesn't appear that a 4th row can be used, the three settings for the fourth row could be eliminated as well.
    Travis
