Data field: Dashboard for Edge
A dashboard for your Edge (or Epix).
You can download it here: https://apps.garmin.com/en-US/apps/444ce575-fbc3-4303-8d01-aebf15d2fe15
Featuring:
  • Big dial to display your current speed;
  • Secondary dial can display either heart rate or power;
  • You can choose between 24 different metrics for the other fields (except on Epix);
  • Display heart rate as BPM, %HRR or HR - %Max.;
  • Display power in Watts or %FTP
Fields to choose from:
  • Speed: current, average or maximum
  • Heart rate: current, average or maximum
  • Cadence: current, average or maximum
  • Power: current, average or maximum
  • Calories
  • Energy expenditure (if available on device)
  • Training effect (if available on device)
  • Distance
  • Time: timer time or total time
  • Altitude: current altitude, total ascent, total descent
  • Heading
  • Clock time
  • Battery level
You can select the data fields and set up the heart rate and power zones with app settings. How to do this is explained in this thread.
    The page you are looking for was not found.
    If you were looking for a specific app, it may no longer be available, or you may not have permission to view it.
    Sorry, it's not been approved yet. Usually it only takes a couple of hours, but it can take up to 3 days. After approval, the link will work.
    It's been approved. You can now download the data field.
  • How to install this app on the edge,garmin Express
    says there is not enough memory space to install applications.
    Thanks
  • Installed onto my Edge 1000, looks nice but can't get into the settings to change anything. Keep getting there was an error retrieving settings from device.
    I downloaded tonight and was able to get it working. Changed the Heart Rate to Power and had it show %ftp.
    The first time I tried it just showed the default settings but I'm not sure if I synched before disconnecting the Edge 1000.
    The second time I connected to Garmin Express, configured the Dashboard settings, saved them, synched the Edge, disconnected and it worked. I'm in portrait mode.
    Good Luck
  • I like this a lot, but can I configure it so it has cadence and speed as the 2 main dials?
    More interesting for training would be to show HF and Power together.
    Is this possible in a future version or better to make both dials configurable?
    Thx
  • Great work! Please add %Grade to the field choices. Very handy for climbing.
  • I sort of got it working, I used Garmin Express on my computer the only thing is every change I make to it is not copying over to my Edge...
    waste of time. Clicking settings in the dashboard app through garmin connect on android brings up an error message. Trying to change fields in Garmin Express on PC will not save to unit.
    I tried numerous times to change fields...saved ...synched garmin 1000...start 1000 - all default fields are there.
    Plugging back into Garmin Express...open app settings all back at defaults. Change ...save ...repeat. Will not work!
