Watchface: Countdown (by TeunMo)
Initially created as 2016 - Countdown this watch face counted down to New Year 2016, but now made configurable to count down to any event.
This watch face features:
  • Time of day;
  • Configurable countdown timer;
  • Battery status;
  • Steps (can be turned of by user setting);
  • Date, if not showing steps
  • Icons for Bluetooth, Alarm and Notifications;
  • ... and more
The watch face can be found here.
*********** Requirements ***********
Connect IQ version 1.2 or above
*********** Settings ***********
  • Event date and time: the date and time of the event to count down to, formatted as described below
  • Countdown message: message to be displayed above the countdown timer
  • Finish message: message to be displayed after the event date and time has passed
  • Show steps: if set to true and steps are enabled on the device, the percentage of daily steps is shown, else the watch face will display the current date.
General information about app settings can be found here
*********** Finish date and time formatting ***********
There's a couple of ways you can format the finish date and time.
Date (required):
  • DD-MM-YYYY (ie 16-03-2016)
  • MM/DD/YYYY (ie 03/16/2016)
Time (optional, default is midnight):
  • HH:mm (ie 14:58)
  • hh:mm (ie 2:58 PM)
Time zone (optional, default is local time zone):
  • z (ie +1)
  • zz:zz (ie +01:00)
Notes about time zones and daylight saving time (DST):
  • If you travel between time zones, it's recommended to specify a time zone;
  • If no time zone is specified, general DST rules for the northern hemisphere (DST between last Sunday of March and last Sunday of October) are assumed. If your country has DST in a different period or if the target date is between the mentioned dates while the current date is not, it's advized to specify a time zone;
  • 'DST' at the end of the date and time forces DST to be calculated for the event date.
The formal ISO8601 format is also supported: YYYY-MM-DDTHH:mmTZD (ie 2016-03-16T14:58+01:00)
Some examples:
  • 16-03-2016 (local midnight)
  • 16-03-2016 14:58 (local time)
  • 03/16/2016 2:58 PM (local time)
  • 16-03-2016 2:58PM (local time)
  • 16-03-2016 14:58 +1:00
  • 16-03-2016 14:58 UTC+1
  • 16-03-2016 14:58 DST (local time, but forcing daylight saving time)
*********** Version history ***********
v1.0: Count down to event of your choice.
v0.x: Initial versions. Counted down to New Year
  • Thanks for another cool CIQ app ! The "easter egg" at midnight on the 31st was a nice touch ;-)
    Maybe you should specify on the settings page that you can display the date or steps in case people don't give the setting a try. Also could the date and battery percentage be centered under the DATE and BAT. labels?
    Thanks. I can indeed add that info to the settings in a next version.
    Nice!
    Right now I see "209.1" as the displayed time until NYC Marathon (which I'll run). The screenshot indicates more details. I suspect the hrs, minutes and seconds kick in a certain nr. of hours before the deadline, but I'd love a continuous: days:hours:minutes(:seconds) display. Could that be an option? Don't see anyone else doing that..
  • The latest 4.70 update has broken "Countdown" (only displays 1's now) on my FR235, can you take a look? Thanks !
    PS - I uninstalled and reinstalled just in case.
    Its a FW issue. Garmin has already been notified and they have escalated the issue.
    So you will just have to wait. Other watch faces were also affected as a result of this.
  • Working again with FW 5.20 on the FR235, unfortunately thanks to Garmin's usual oversights no ConnectIQ app can be configured at this point so I'm just getting the "Good Luck" message, which is something positive I suppose ;-)
