Since update on 1-24 steps no longer show in GCM activity card. VA4
Steps are NOT in new release FIT file. They are in the previous release.
However, they are in the HISTORY of activity on the watch.
Note: Previously I was getting "Steps to Fit" and jmf-dtf-cycling-vo2-max-simple" data filelds that I use on the VA4 outdoor WALK app.
Neither of these show now in the GCM activity card.
Yes. Steps show in app while using it
Not showiing in FIT file
I can't see how to respond to you in CIQ.
I also sent you an email.
Hello, I just started using your app on my Vivoactive 4S. Is there any way to calibrate after passing a mile like you would with a treadmill run? My cadence varies often because I change speeds and inclines on my treadmill, but the distance recorded on the watch app vs treadmill is way off.
Used on my Fenix 7 snow walk in door application provided for it. It turned on the GPS and use the GPS for distance computation. This is not what I wanted. Gave it one star because I am very unhappy. An indoor Walk application should use steps for distance not GPS.
REVISED: MUCH happier now. The issue appears to be that the Fenix system default for "Satellites" is "All Systems", and the app merely accepted the system default. All Fenix Garmin apps for "Indoor" override the system default in their settings. Upgrading to 3 stars because this works fine for my needs, but could either use configuration options or to have the Satellites setting automatically overridden by the app to "off".
If it turned on GPS, that's a bug in the f7 FW and not in this app. Contact Garmin
Not so much a bug in the Fenix as the result of the application apparently using the system default for "Satellites". Fixed now by turning the system default for "Satellites" to "Off" from the factory setting of "All Systems". Because this is specifically an indoor app and has no configuration options, it seems like the app should explicitly use no Satellites rather than the system default.
Awesome app. Only thing I would ask for is if it's possible to customise a screen by picking which data fields we want displayed in that screen.
I'm happy with the time and HR, but I'm constantly scrolling screens to monitor my steps, daily steps, distance, and would be happy to swap HR for duration/recorded time too.
No, with CIQ apps they must specifically turn on GPS. This app doesn't do that. Sounds like the Fexix turns it on when they shouldn't.
