Watchface: Chronometer
A simple watch face for the Vivoactive with integrated step count and move bar.
If you have any suggestions or need any support, please post to this thread.
Version History
1.0
  • Initial release
1.1
  • Display settings
1.2
  • Tweaked 12h time position
  • Added battery percentage display option
    Centered Text
    Lladnaar,
    Great watch face! I've experimented with a number of watch faces and I really appreciate the informative-yet-simple approach your design took. If I may make one suggestion, the centering of the time in 12-hour mode "feels" off. While technically it is probably exactly correct (the division between the hour and minute is exactly half-way across the screen), the time actually appears to be justified-right. If you could figure out a way to keep the actual text of the time centered across the screen, it would really help. I hope that is clear. Definitely not trying to take anything away from your great work. Thanks!
  • Time position
    Hi, thanks for the feedback.
    I know what you mean. With a one digit hour it feels off, and even when the first digit is a 1, it's much narrower and a bit right justified. I'm not sure it would be quite right to move the display depending on what the hour currently is, but I'll see if I can find a more pleasing position for 12h mode display.
