A dozen data field designed for the Air traveler. Designed with the help of a Pilot.
This multi data field provides navigation, distance remain and ETE to one waypoint, which the waypoint is programmable from Garmin Express or Connect phone app. The way point is entered in degrees only. If either the Longitude or Latitude is negative use the check box to indicate negative.
Custom Destination (Long/Lat) Waypoint entered through Connect App or Garmin Express.
Supports only one way point.
How to use:
From the custom user configuration menu in Garmin Express or Garmin Connect, enter your destination Longitude and Latitude waypoint in decimal degrees. If the coordinate Long/Lat is negative set the negative button. The ETE and Distance Remaining are determined by the way point position and your current position.
v1.1
- adds heading bug
- reduced the rolling average for speed
1.0.1
- Cosmetic changes.
- Reduced how often ETE is calculated.
Data Fields:
-Max Speed (Metric or Statute)
-Speed (Metric or Statute)
-Average Speed (Metric or Statute)
-Altitude (Metric or Statute) (Barometer Based SDK limitation should be GPS based)
-Distance (Metric or Statute)
-Distance Remaining (Metric or Statute)
-Elapsed Timer
-Estimated Time Enroute ETE
-GPS Strength (NA, "Last" Last Known Position, GPS-2, GPS-3, GPS-4)
-Fast read battery meter
-Bluetooth Connectivity
-Time of Day 12hr or 24hr
Field Locations:
Time | Elapsed Time
Speed | Dist./Dist. Remaining
----------Battery----------
Avg SPD | Altitude
GPS | ETE |Max SPD
Bluetooth
Future Version (coming soon)
- Multi-waypoints
- Airport codes as waypoint
- New separate App for Geocaching. This app will work "as is" for geocaching, but the distance not ideal for geocaching,.
