Watchface: M2
This is the support thread for the M2 watchface:
 has created a Facebook group for designs here: https://www.facebook.com/groups/423319952037948
And this PDF files contains a quick visual index to the designs posted in this thread: >>>    ForumProfiles1.pdf    <<<
To create your own design or modify one, install & use the M2 Designer app on your watch. These are the steps you would go through:
  • Optionally paste a text code into the "Profile Text" setting of M2 Designer & save the settings, or load one of your previously saved designs (either via the settings or the in-app menu).
  • Run the M2 Designer app (found underneath your activities list) and create your design.
  • Once you've finished, open the Garmin settings for M2 Designer.
  • The text code in "Profile Text" will now represent whatever your design looks like, so copy the text code from "Profile Text" - and be careful to select the whole text.
  • Close the settings for M2 Designer.
  • Open the Garmin settings for M2 (watchface) instead.
  • Delete any text that was already in "Profile Text" - this step helps to avoid potential problems
  • Paste the text code into "Profile Text".
  • Save the settings.
  • Now when you view the M2 watchface it will show your changes.
A guide for accessing the Garmin settings is here: https://forums.garmin.com/developer/connect-iq/w/wiki/14/changing-your-app-settings-in-garmin-express-gcm-ciq-mobile-store.
Profile text for the default display = 01Ys2525111WDPO1011WwWO020Vc121VZ11WwXw03X7C11WwVd035C13NC13XDC19010000
Notes on 12-hour and 24-hour display options - see 4 posts down (with Oldest first) ...
See the latest posts by clicking newest (if it is visible just below) or using the page navigation (if visible at the very bottom).
  • Thanks for sharing. Just loving it.
  • can't thank you enough..
    this app should be garmin native in my opinion..
    code:
    01Ys2515101WDKO1011YJWt2234Ve214W01YIWY23X7713N7135713SC13A718X5G0EW0W0Ve1W5XU04G1Vr3VVF13NF13OF13NF13VrF18X750VxVe0W01W0Xv04N0Ve3VXF11YIWG260VdVn3Ve111VeX104Q0Ve3VmF17XEW0VeWLWP3Wg
    updated code:
    01Ys2515101WDKO1018X750VxVe0W08X5G0EW0W0Ve1YBXN23Vj043Vk041YJWk2234Ve214W01YIWO23X7713N7135713SC13A711YIW6260VdVn3Ve141VYXi14N0Ve3NF13VXF41NXO14G1Vr3NF13VVF43NF13OF43NF13WpF41GX414Q0Ve3NF13VmF47XEW0VeWGWP3Wg1WBVy23Vp0Ve1WBWE23Vo04
    vertical line and associated numbers intensity mins
    next sun event above time
  • Hi,
    Is it possible to add a field with barometer (small arrows and sea pressure) ?
    Best regards
  • Hi Slight smile There is a pressure value you can display (and units in text "mb") - but that is all currently.
    And it isn't possible for me to add more features now, as the app is using all available memory. So adding arrows for the display of pressure is a good idea, but not possible, sorry Disappointed
  • Hi, Thanks. Is it the number the sea level pressure or just the value from the sensor ?
    The difference is very important 1024 hpa at the sea level doesn't mean the same at 2000 m in the mountain ;-)
  • Aha I see - yes you are right, it just displays the pressure from the watch sensor. So it is not the pressure at sea level.
    I guess to calculate it at sea level requires an extra calculation using the altitude - unfortunately the memory is so tight it's not even possible to add that as an option Disappointed
    I'll keep a note though in my "to do" list as one day maybe it will be possible to add ...
  • Hi,
    Thanks.
    I think that it's a native garmin field because it possible to add it to the garmin watch face.
    Best regards
  • 01ZW2525111WDPO10170Y20XGXGUYi1XLXC023J221J21XGXI023J121J17142XGX1Z2B7010XGX1Z231XGWX03X7213NF135213NF13XD213NF13E213XJ218050Vx1009F100001XGVj03VV214L011XGK03Ve214R011XGYi0XOE013Va213U214H01WMC011XGW803Vj213Q213Vk214U013Wr211W3Vy0cIR11cb0Zl0W3WCFVV1W3W00c
    YR111XGXG0
    Former Member over 2 years ago in reply to WP
    Where can I find it?
    Thank you
    Jammino
  • You can enter the code they give in the settings for the watchface (in whichever Garmin app you use) - it is the top "Profile Text" setting.
