Watchface: M2
This is the support thread for the M2 watchface:
 has created a Facebook group for designs here: https://www.facebook.com/groups/423319952037948
And this PDF files contains a quick visual index to the designs posted in this thread: >>>    ForumProfiles1.pdf    <<<
To create your own design or modify one, install & use the M2 Designer app on your watch. These are the steps you would go through:
  • Optionally paste a text code into the "Profile Text" setting of M2 Designer & save the settings, or load one of your previously saved designs (either via the settings or the in-app menu).
  • Run the M2 Designer app (found underneath your activities list) and create your design.
  • Once you've finished, open the Garmin settings for M2 Designer.
  • The text code in "Profile Text" will now represent whatever your design looks like, so copy the text code from "Profile Text" - and be careful to select the whole text.
  • Close the settings for M2 Designer.
  • Open the Garmin settings for M2 (watchface) instead.
  • Delete any text that was already in "Profile Text" - this step helps to avoid potential problems
  • Paste the text code into "Profile Text".
  • Save the settings.
  • Now when you view the M2 watchface it will show your changes.
A guide for accessing the Garmin settings is here: https://forums.garmin.com/developer/connect-iq/w/wiki/14/changing-your-app-settings-in-garmin-express-gcm-ciq-mobile-store.
Profile text for the default display = 01Ys2525111WDPO1011WwWO020Vc121VZ11WwXw03X7C11WwVd035C13NC13XDC19010000
Notes on 12-hour and 24-hour display options - see 4 posts down (with Oldest first) ...
See the latest posts by clicking newest (if it is visible just below) or using the page navigation (if visible at the very bottom).
  • >>>>> is it possible to insert an indicator (up / down arrow) for the increase or decrease of atmospheric pressure?
    Yes ... but only when there is more memory! (Sorry Disappointed) It's a good suggestion, so I'll make sure it's on my "wish list" for the future. One day it will be possible Slight smile
  • Hi - the temperature field shows the temperature as measured by the watch, and unfortunately I just checked the specs for the Forerunner 245, and it looks like it doesn't have the temperature hardware Disappointed
    There may be a version with the "weather temperature" at some point (which might be what you are after?) ...
  • Hi Mark, can I make a request please?
    it's not functionality; it's the settings screens within the connect app - so it might be outside your control.
    Basically,  it's hard to know which profile numbers are empty / available to use.
    I've got a watchface in number 1 - when I select and load profile #1, it calls that code up.  All good perfect.
    I haven't got a watch face saved to number 3....but  when I load that profile, the code line doesn't show as empty.... it shows the code for the last valid stored profile I looked up.
    this seems be the case with the designer app as well as the watchfaces themselves.
    or maybe this is just a glitch on my phone and tablet.
    Might is be possible to tweak things so an empty profile shows an empty code line please?
    thanks
    Allen
  • 01ZC2525VxW31WDPO1018X450Vx30070ZD0OY6KC70Z90YoY6KC70Z90YoW7KC70Z90Y5OKC70Z90NW7KC70Z90W6OKC70Z90W6YpKC70Z90Y5YoKC705VfX676S70507X6S67050Z5X6S67050X6Z56S1Y4XB03X7151Y4Wo0357173Zw3X6Y4KWI70ZA0X6Y4KWD1X6Xx03Va713U111X6Xe04VY147Ca43W8X6KWI70ZA0W8X6KWD1W8X403
    Ve711W8Wd04R147DZm3X6W8KWI70ZA0X6W8KWD1X6W303Vn711X6Vc04Q147340X5XjF87EbD0X6X6BXf7EcF0X6X64XY7EbD0X6X6AWI74bD0X6X6AYO74bE0X6X64YG74bD0X6X6AWS70ZA0X6X6KO70ZW0X6X6KJ1X6Wy04B02
    • Stile Ferrari:
      01ZC2525VxW31WDPO1018X450VxVd0070ZD0OY6KC70Z90YoY6KC70Z90YoW7KC70Z90Y5OKC70Z90NW7KC70Z90W6OKC70Z90W6YpKC70Z90Y5YoKC705VfX676S70507X6S67050Z5X6S67050X6Z56S1Y4XC03X7651Y4Wn0357173Zx3X6Y4KWD70ZA0X6Y4KW81X6Xz03Va613U711X6Xg04VY117CZl3W8X6KWD70ZA0W8X6KW81W8X60
      3Ve611W8Wf04R117DZm3X6W8KWD70ZA0X6W8KW81X6W503Vn611X6Ve04Q117010X5XlF87EbD0X6X6BXf7EcF0X6X66XY7EbD0X6X6AWI74bD0X6X6AYO74bE0X6X66YG74bD0X6X6AWS70ZA0X6X6KO70ZW0X6X6KJ1X6Wy0
  • hi mark, any chance for new fonts like casio/digital style?
    thanks!
    you work is fantastic!
  • Is there something missing on my designer? I can't find how to make circles. I can make rings but they're all a set size and position where I've seen some watch faces with circles all over the place
  • - yep if you create a "Dial", then you can change the Style of that between Rectangle, Circle (filled centre), Arc (hollow centre) or Hand.
    Then try changing the Height to change the size of the circle/arc/hand, and also Width (works for the arc & hand) - to see what they do Slight smile
  • OK thank you, I'll investigate tonight
  • I can't find dial anywhere, it's not on the M2 menus v12 spreadsheet either
  • @Jack681 - ah "Dial" is the newer name for "Rect" (I renamed it when I added the extra styles)
    So if you still see "Rect" in M2 Designer then you will need to update it to get the latest version.
    (And I thought I updated the V12 menu spreadsheet to V13 - but must have forgot Slight smile I'll do it now!)
