Watchface: M2
This is the support thread for the M2 watchface:
 has created a Facebook group for designs here: https://www.facebook.com/groups/423319952037948
And this PDF files contains a quick visual index to the designs posted in this thread: >>>    ForumProfiles1.pdf    <<<
To create your own design or modify one, install & use the M2 Designer app on your watch. These are the steps you would go through:
  • Optionally paste a text code into the "Profile Text" setting of M2 Designer & save the settings, or load one of your previously saved designs (either via the settings or the in-app menu).
  • Run the M2 Designer app (found underneath your activities list) and create your design.
  • Once you've finished, open the Garmin settings for M2 Designer.
  • The text code in "Profile Text" will now represent whatever your design looks like, so copy the text code from "Profile Text" - and be careful to select the whole text.
  • Close the settings for M2 Designer.
  • Open the Garmin settings for M2 (watchface) instead.
  • Delete any text that was already in "Profile Text" - this step helps to avoid potential problems
  • Paste the text code into "Profile Text".
  • Save the settings.
  • Now when you view the M2 watchface it will show your changes.
A guide for accessing the Garmin settings is here: https://forums.garmin.com/developer/connect-iq/w/wiki/14/changing-your-app-settings-in-garmin-express-gcm-ciq-mobile-store.
Profile text for the default display = 01Ys2525111WDPO1011WwWO020Vc121VZ11WwXw03X7C11WwVd035C13NC13XDC19010000
Notes on 12-hour and 24-hour display options - see 4 posts down (with Oldest first) ...
See the latest posts by clicking newest (if it is visible just below) or using the page navigation (if visible at the very bottom).
  • I recharged it and it works on my watch. What model of watch do you have?
  • So cool to see all the new designs from everyone!
    Especially how you are making even the simple hands look nice Slight smile
  • I tried the version 2 of those profile strings in the simulator and, and it works partially up to this point:
    01ZC2525VxW31WDPO1011XqXB023F51XqVy021F17X7Vd3WuX47XL1WIXq23VeB11VbVy13WpB11WIWu23VnB17020WuVtBB7020WxX4J37020WxWGJ37020WxWXJ37020WxWnJ37020WxXLJ37020WxXbJ37020WxXuJ37020WyYDJ37030X5VjYQ27030X6Z4Yd11X6YW03X7C53QBW135C11X6I03VvC13QAW1BM711WYXq04R1Vd1WYWu04
    Q1Vf1WYVy04L1R80B9B80080BCER0080BFHO0080BIKVd008WW1L90107030X6YNYY21VoXN03WoB11WZXN04B1VW7030X6VoYY11VwWR03VrB11WY70WT06YN
    But then no further. I tried just deleting letters off the end one by one until it worked ...
  • Can you post an image of the contents of the folder which is up one from the bat files? (It should be called the Bin folder)
  • >>>> Would it be possible to have a larger font size for the data (like hours / minutes)? For old people like me who don't see the small text ;)
    Can you list exactly which data items you want in the larger font, then I can add them individually Slight smile (They can only include number digits - not even decimal points as the large font does not include those Disappointed)
    Unfortunately I made the large font items and normal font items a totally separate format, which I can't change now until I make a newer watchface (e.g. M3), and then I can improve things!
  • This work fine for me
    01ZC2525VxW31WDPO1018Y9BVt000Vf70Zn0X6X6WgYu70ZA0X6X6XEYr7EbD0X6X6AXa7ObD0X6X69YE70ZA0X6X6KVu70Zn0X6X6KVp70Z90VXY1K770Z90YfY1K770Z90YgWBK770Z90Y1VWK770Z90VXWCK770Z90WAVXK770Z90WEYhK770Z90Y1YgK770VfVfX6KAA70Vf0LX6AA70Vf0YsX6AA70Vf0X6YsAA1X8YB03VeC21X8Xi04R
    021X8W804Q021X8Ve03VnC270ZA0X6X6KVj1X6Wx035C11X6YE03VeC11X6Xk04R0Vf1X6WA04Q0Vf1X6Vg03VnC1
  • >>>> It doesn't seem that either the paused or stopped visibility options are working for me if I stop an activity and choose "resume later" (I'd like to be able to display an icon reminding me that the activity is waiting in the background to be resumed).
    Ahh that's a shame - I'm guessing "resume later" temporarily ends the activity (until you do resume it).
    I can't see any way in the CIQ API that it's possible to tell if an activity is in that state unfortunately Disappointed I'll investigate a bit further and see if I can find anything.
    Currently these are the only values I see access to (and they correspond to the 4 values I allow you to choose):
    Name Value Since Description
    TIMER_STATE_OFF 0
    2.1.0
    The timer is off. There is not an active recording
    TIMER_STATE_STOPPED 1
    2.1.0
    The timer is stopped. The recording is active, with the timer stopped.
    TIMER_STATE_PAUSED 2
    2.1.0
    The timer is paused. The recording is active with the timer paused. This state occurs when the timer is active, but has been stopped with the Auto-Pause feature.
    TIMER_STATE_ON 3
    2.1.0
    The timer is on. The recording is active and the timer is running.
  • Distance, steps, date, etc.
    I have a bit of presbyopia or short arms Slight smile
    Thx
  • The stopped & paused visibility options work perfectly on my Fenix 5+, I use them all the time on my watch face.
