Watchface: M2
This is the support thread for the M2 watchface:
 has created a Facebook group for designs here: https://www.facebook.com/groups/423319952037948
And this PDF files contains a quick visual index to the designs posted in this thread: >>>    ForumProfiles1.pdf    <<<
To create your own design or modify one, install & use the M2 Designer app on your watch. These are the steps you would go through:
  • Optionally paste a text code into the "Profile Text" setting of M2 Designer & save the settings, or load one of your previously saved designs (either via the settings or the in-app menu).
  • Run the M2 Designer app (found underneath your activities list) and create your design.
  • Once you've finished, open the Garmin settings for M2 Designer.
  • The text code in "Profile Text" will now represent whatever your design looks like, so copy the text code from "Profile Text" - and be careful to select the whole text.
  • Close the settings for M2 Designer.
  • Open the Garmin settings for M2 (watchface) instead.
  • Delete any text that was already in "Profile Text" - this step helps to avoid potential problems
  • Paste the text code into "Profile Text".
  • Save the settings.
  • Now when you view the M2 watchface it will show your changes.
A guide for accessing the Garmin settings is here: https://forums.garmin.com/developer/connect-iq/w/wiki/14/changing-your-app-settings-in-garmin-express-gcm-ciq-mobile-store.
Profile text for the default display = 01Ys2525111WDPO1011WwWO020Vc121VZ11WwXw03X7C11WwVd035C13NC13XDC19010000
Notes on 12-hour and 24-hour display options - see 4 posts down (with Oldest first) ...
See the latest posts by clicking newest (if it is visible just below) or using the page navigation (if visible at the very bottom).
  • il mio ultimo sforzo, ho preso spunto dalla maschera di Krafty.
    01ZC2525VxW31WDPO1011XqXB023F51XqVy021F17X7Vd3WsX47XL1WIXq23VeB11WIWR23VrB11WIXN23WoB11VbVy13WpB11WIWu23VnB17020WuVtBB7020WxX4J37020WxWGJ37020WxWXJ37020WxWnJ37020WxXLJ37020WxXbJ37020WxXuJ37020WyYDJ370W10X5QYQQ70W10X6YhYdQ1X6YY03X7C53QB335C11X6H03VvC13NA1B
    M711WWXq04R1Vd1WWXN04B1Vr1WWWu04Q1Vf1WWWR04G1U1WWVy04L1R
  • Are you copying the blue text from this image?
    Are you doing it for both "Profile 1st Half" and "Profile 2nd Half"?
    After selecting the text do you right click and select "copy" to copy it?
    Try pasting the 1st and 2nd half into a new document - and make sure to keep them separate from any other text by at least one blank line (and from each other).
    Count the number of characters on each line - it will be less than 255.
    Those are the only suggestions I can think of Slight smile
  • As far as I know that's what I'm copying. It's coming out as 255 for the 1st profile. I think I'll have to make a new face and see if it works that time
  • 255 length is fine
    Just make sure to copy the entry for 2nd half of the profile text as well
    Then paste them both here (separated by a blank line) - so we can check them Slight smile
    The last text you posted was a single line and more than 255 characters (so it was an impossible one)
    If you are pasting them to your M2 watchface settings, then you need to enter the 1st half in the top setting, and the 2nd half in the second setting. (The Garmin settings have a limit which prevents entering lines which are too long so it has to remain split in two).
    If the 1st half is less than 255, and the 2nd half is blank - then you need to make sure in the M2 Garmin settings that the 2nd setting is also blank. Both the first half and 2nd half must exactly match.
  • This is what it gave me this morning although I can't check it because the iq connect store isn't working again
    01Ys2525111WDPO1011WwWw023QVd21QVd1VoWV03X7851WuWW035811Y0WW03XD811X6YE03Ve751WgYE04R0Vd1WSU03Va711W6U04H011XaU03Vr711XBU04G01HWwW103Vm71HWNW004Q0VeHWwW003Vm71HVwW003VX71HVeW004N09HXqW003Vj71HYFW003Vk71HXaW004U0O1WvXG03QJVd1WnVb04VX017010WwWqYn27010WwWQYn
    27010WwVnYG27020WwX0YN47020WwX6YQ27020WwXBYO18X540UQ008YJ4VxUP00
    First is 255 exactly
  • Cool, that loads for me Slight smile
  • I still can't get on to the iq settings page. I'll have to try garmin express when I get in. I looks like I need to tinker with a few bits as well. Thanks for trying it
  • I cannot get to the iq connect either...
  • Ho inserito l'indicatore del carico di lavoro
    la batteria del corpo sarebbe migliore :(
    la stella è il peso
    la barra verticale è la batteria
    V.1
    01ZC2525VxW31WDPO1011XqXB023F5 1XqVy021F17X7Vd3WuX47XL1WIXq23 VeB11VbVy13WpB11WIWu23VnB17020 WuVtBB7020WxX4J37020WxWGJ37020 WxWXJ37020WxWnJ37020WxXLJ37020 WxXbJ37020WxXuJ37020WyYDJ37030 X5VkYQ27030X6Z2Yd11X6YX03X7C53 QBW135C11X6J03VvC13QAW1BM711WY Xq04R1Vd1WYWu04
    Q1Vf1WYVy04L1R80B9CO0080BDGW00080BHKVd008WW1L90107030X6YPYY21VoXN03WoB11WZXN04B1VW7030X6VoYY11VwWR03VrB1L90107030X6YPYY21VoXN03WoB11WZXN04B1VW7030X6VoYY11VwWR03VrB1L90107030X6YPYY21VoXN03WoB11WZXN04B1VW7030X6VoYY11VwWR03VrB1L90107030X6YPYX30
    v.2
    01ZC2525VxW31WDPO1011XqXB023F51XqVy021F17X7Vd3WuX47XL1WIXq23VeB11VbVy13WpB11WIWu23VnB17020WuVtBB7020WxX4J37020WxWGJ37020WxWXJ37020WxWnJ37020WxXLJ37020WxXbJ37020WxXuJ37020WyYDJ37030X5VjYQ27030X6Z4Yd11X6YW03X7C53QBW135C11X6I03VvC13QAW1BM711WYXq04R1Vd1WYWu04
    Q1Vf1WYVy04L1R80B9B80080BCER0080BFHO0080BIKVd008WW1L90107030X6YNYY21VoXN03WoB11WZXN04B1VW7030X6VoYY11VwWR03VrB11WY70WT06YNYY21VoXN03WoB11WZXN04B1VW7030X6VoYY11VwWR03VrB11WY70WT06X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X30X
