Watchface: M2
This is the support thread for the M2 watchface:
 has created a Facebook group for designs here: https://www.facebook.com/groups/423319952037948
And this PDF files contains a quick visual index to the designs posted in this thread: >>>    ForumProfiles1.pdf    <<<
To create your own design or modify one, install & use the M2 Designer app on your watch. These are the steps you would go through:
  • Optionally paste a text code into the "Profile Text" setting of M2 Designer & save the settings, or load one of your previously saved designs (either via the settings or the in-app menu).
  • Run the M2 Designer app (found underneath your activities list) and create your design.
  • Once you've finished, open the Garmin settings for M2 Designer.
  • The text code in "Profile Text" will now represent whatever your design looks like, so copy the text code from "Profile Text" - and be careful to select the whole text.
  • Close the settings for M2 Designer.
  • Open the Garmin settings for M2 (watchface) instead.
  • Delete any text that was already in "Profile Text" - this step helps to avoid potential problems
  • Paste the text code into "Profile Text".
  • Save the settings.
  • Now when you view the M2 watchface it will show your changes.
A guide for accessing the Garmin settings is here: https://forums.garmin.com/developer/connect-iq/w/wiki/14/changing-your-app-settings-in-garmin-express-gcm-ciq-mobile-store.
Profile text for the default display = 01Ys2525111WDPO1011WwWO020Vc121VZ11WwXw03X7C11WwVd035C13NC13XDC19010000
Notes on 12-hour and 24-hour display options - see 4 posts down (with Oldest first) ...
See the latest posts by clicking newest (if it is visible just below) or using the page navigation (if visible at the very bottom).
  • green: battery
    orange: intensity
    red: training load
    blue: steps/distance
    jellow: active calories
    altitude
    heartrate
    part 1:
    01ZC2525111WDPO1011X6Wa020E13N3121C17030X6XnYC17030X6WLYE17030X6W41VZ1X5Xv03X7613N3135C13N313XD617030X6YNXX17030X6VlXO183B0VxVo02XLX6K03VeB11WfVt23VrB11YRVt23VnB11XoYU04VW011X6YU03Vv618XE7VlVwVe008Ya7D2Vd001YpWy14Q0Vm1DWy04G0Vi8XH7HTVm008Y77VhVVVr001XkJ04
    part 2:
    R0Vd1X6X608W25EG2001X6X60
  • Hi, nice work !!
    My configuration  : 01Ys2525111WDPO10183B0VxVVG09A100001WwWN020P121O11WwXa03X7713N7135713N713XD711WwVy0WMC01XOE01ZCH0VcWsF01WrVZ718AH0VxVe00
    Blue ring for battery indicator
    Orange slashed ring for intensive minutes
    White seconds indicator
    Icons for alarm / phone connexion / battery low (red) / notifications.
    That was hard but not impossible !
  • Hello , I found a strange problem with the PC emulator: Thursdays are shown as "THURS" there, but still displayed "THU" on the screen of my Fenix 6X.
    Is this a known issue, could I fix this on my side, please?
    Thanks!
  • Unfortunately yes it's a known issue! Using the simulator you are now entering the realms of Garmin CIQ development ... and this is a bug in the simulator on the Garmin side. So now you know what developers have to put up with Slight smile
    It's not something I or you can fix unfortunately ...
    Bit of a pain if you are trying to make an alignment. You could switch it to display month instead of day temporarily (and then switch it back again).
    Here is an official bug report for it: https://forums.garmin.com/developer/connect-iq/i/bug-reports/simulator-uses-thurs-for-thursday-in-3-0-10 - but it's from April 2019 ... over a year ago
    I just voted it up!
  • , thank you for the reply and for the hint!
    I also upvoted this ticket
  • "The Dark SideSmiling imp watchface, or "Red Sith
    Not only because of cookies :), but also to match the new bracelet.
    If everything is fine, the icons are, no doubts, red!
    In case of issues - low battery, unread messages (like in the image above), unset alarm, high heart rate or time-to-sleep ;) they change to the wrong jedi guardian blue color Stuck out tongue
    The code:
    1st half:
    01ZW2525111WIFVX11170Vd0XGYhZW41WFXJ023Q51YHXJ021Q51XGXm03QJ570Vd0XGX7ZW41WXYo03DH11XCYo0BVWH11XTYo0BKH11XqYo03EH11Y8Yo03SH11YJYo034H11WUWY03X7J11XRWY036J11XpWY03SJ11YCWY03BJ170Vd0XGWPZW470Vd0XGVpZW470Vd0ViWl4Vj70Vd0YoWl4VjZ9PWc04I1VVYNPWc04I1VdXbZ8Wc04E1
    2nd half:
    VVXLZ8Wc04E1VdWpVuVx04F1VVX5VuVx04F1VdVnXkS04J1VVW3XkS04J1Vd70Vd0WGW74Vc70Vd0YGW74VcWJYiVx04C1Vd1XGVw03WBH11XYVy03QH11XqVw03WmH11WbVw0BKH11WqVw0BRH1WZYiVx04C1VV70Vd0XGT4Vj1WmO04R1VddXWmO04R1VV70Vd0XG3YEU70Vd0XGZTXkU
    P.S. I'll try to match the red colors but seems that the palette of Fenix is a bit limited...
  • Wow, that bracelet is awesome Slight smile
  • 01ZW2525111WDPO1017040XGYvYdL7040XGWcZWL7040XGW8Z4L7040XGVeYdL1XGXF023D121D11W9WV03X7321XXWV035323NC13XD321YhWV03E321XGYn23Va321WbW123Ve321X4Vy24R031YCW123VV321YdVz24L021XVYn03U221XGYO050011111081D0VxVs0Vq1XMVW23Vr321XaVW04G027CVsVqXGX1YXA8000VxVq009dGVs0
    2nd half:
    000
  • This was 4 years ago, right? :-)
  • Lol, no it’s actually from the future! You see: 5 SEP 36, that’s from 2036, in sixteen years ;)
