Datafields: PerfectDatafield HR
Please, feel free to comment or ask any modification. I'm not a developer I just tried to make a datafield that I needed for my trainings days and share it with you.
Enjoy the datafield ;)
**** WHY ****
I've been looking for a long time a datafield to check my HR and average HR but i did not find anything. So I've tried make one.
**** DESCRIPTION ****
This is a perfect datafield to check your Hearth Rate and Average HR and calories.
**** SPECIAL THANKS ****
Many thanks to @kpaumann (https://apps.garmin.com/es-ES/apps/aacfc2de-b61e-40cc-a83d-52f46f9d263d) His project helped me to make this one datafield.
Project: https://github.com/kopa/BikersField
**** HOW TO: Install ****
- Long Press UP
- Settings
- Apps
- Bike/Run
- Data Screens
- Screen N
- Layout
- Select single field
- Field 1
- Select ConnectIQ Fields
- Select PerfectDatafield
- Long Press DOWN to go back to watch face
**** FEATURES ****
A HR: Average HR
HR: Hearth Rate
CAL: Calories
A SPEED: Average Speed
DIST: Distance
ELAPS: Duration (Elapsed Time)
  • Averaging
    Hi, I really like to data field and was just wondering what time period you are using to do the averaging.
    Hi! thanks for download it.
    I just called to Garmin's Method that retrieves the average info, the fields info are not calculated for me. I only change the info format if I needed to display "X.XX" or "X:XX" data.
    I use my datafield every days for training. Have you seen any issue?
  • issues
    no issues, I like the bold font. Wonder if you could make the timer font larger. It was hard to see in the dark.
    Let me check it.
    The timer has this font because if you are training for a long time (more than 1hr) it was overlapping the distance field.
  • Great field, however here it always shows speed as 0.0, the average speed is correct though. Indoor activity with foodpod, latest FW beta.
    Hi, I think it will be a little complicated to be tested for me because I dont have the Garmin's footpod. I will check the code.
    thanks so much!!
  • Is it possible for you to do one with pace instead of speed? I love this and the one with cadence but when I run I would like to see pace instead.
    Hi!
    Thanks so much for download it! Let me see what I can do.
    Thanks a lot!
    Hi there! Are you able to replace calories to the actual speed?
