Data field: Heart rate and Time in Zone
The Heart Rate and Time in Zone data field enables you to see all the relevant heart rate data in one screen.
This data field shows your current heart rate and zone in a gauge and the time spent in each zone during the current activity.
Some screen prints:
You can find the data field here: https://apps.garmin.com/en-US/apps/53505cae-a7d8-4fcb-97fa-4ad28a244d90
*********** Features ***********
- Heart Rate in beats per minute (BPM), percentage of maximum (HR %Max.) or percentage of heart rate reserve (%HRR);
- Heart Rate and Zone gauge;
- Time spent in each zone during the current activity;
- All zones are fully adjustable with the app settings editors in Garmin Express and Garmin Connect Mobile (see support);
- The default zones are 50-60, 60-70, 70-80, 80-90, 90-100 % of your HRR, with your maximum heart rate based on your age. These will be used if you don't set the app settings.
*********** Requirements ***********
Connect IQ version 1.2 or above
*********** Feedback and support ***********
If you have any feedback or if you need some support, please leave a message in this forum thread.
General information about app settings can be found here
To determine your resting heart rate, you can use my Resting Heart Rate data field.
*********** Version history ***********
v1.1:
  • Added option to choose background color;
  • Time in Zone is now shown after exercise has ended.
v1.0: Initial version
*********** Setting up the data field ***********
You can set your zones in the User Settings section of Garmin Connect Mobile or Garmin Express.The setup is the same as setting your zones in Garmin Connect, based on %HRR. Unfortunately the order in which the settings appear might be different.
If personal zones are not set, default will be set based on your age. Currently it's technically impossible to retrieve your zones directly from the device or Garmin Connect
Setting up the zones in Garmin Express (recommended)
  • Go to "Manage Apps", a list of all your apps is shown;
  • Look for the Heart Rate and Time in Zone data field and press the "..." besides the data field name, a page is shown where you can change the settings;
  • Change the settings to the appropriate values:
    • Display Heart Rate as: display the current heart rate in BPM, HR %Max. or %HRR.
    • Resting Heart Rate: fill in your resting heart rate. If set to the default of -1, it will get the value from your connect profile
    • Zone 1 %HRR: lower bound of zone 1 as % heart rate reserve (HRR). HRR is the difference between your maximum and resting heart rate. If you prefer to use HR %Max, set resting heart rate to 0.
    • Zone 2 t/m 5 %HRR: same as zone 1. Make sure that the values are incremental, because the data field will show the first zone that fits and if they are not incremental, you'll get unexpected results. If you want to use less that 5 zones, set the values of the zones that you don't use to 100. More than 5 zones is currently not supported. If you do want more, please leave a comment and I might be persueded to add more.
    • Max Heart Rate: fill in your maximum heart rate. If set to the default of -1, your maximum heart rate will be estimated based on your age
    • Background color: Choose the background color for the data field
  • Press "Save" to save the changes. The new values will automatically be send to your device.
I you want to check whether the new values are saved to your device, you can simply go to the settings page again. Garmin Express will always load the settings directly from the device.
Setting up the zones in Garmin Connect Mobile
It's possible to set up the zones in Garmin Connect Mobile (GCM), but in the current version the settings might be displayed out of order. Therefore using Garmin Express is recommended.
The following explanation is based on GCM for Android. GCM for iPhone should be (almost) the same.
  • In the menu go to "Garmin Devices";
  • Select your device from the list;
  • Select "Connect IQ Apps";
  • Select "Data Fields";
  • Select the Heart Rate and Time in Zone data field;
  • Select "Settings" (if your device does not have Connect IQ 1.2 installed, you'll get a message "An error has occurred");
  • Change the values (as described in the Setting up the zones in Garmin Express section above);
  • Select "Done" to save the values to your device
Same as with Garmin Express, you can check the settings by going to the Settings page again.
  • Bug: horizontal lines
    I have installed it on Edge1000 with firmware 7.0.0.
    If the heart rate crosses the border from zone4 to zone5, horizontal lines are displayed. These lines are red or orange. bad picture: https://www.endomondo.com/resources/gfx/picture/31162244/big.jpg
    I also can not edit any IQ settings. These bug seems to be known and under construction in this thread: "Data field: Dashboard for Edge".
  • I have installed it on Edge1000 with firmware 7.0.0.
    Based on what I understood you can have this APP only if you set the Data page with 1 field only. Based on the picture that you posted it appear more than 1 field.
    Former Member over 9 years ago
    Nice app but possible with potence
    Hi,
    It would bew possible to this app with potence data, it would be amazing.
    That´s a lot.
  • Are there news on how to set up the zones?
    I updated to the latest software my garmin 520,garmin connect app on the iPhone and garmin express on the mac. But still the zones don't get saved
    Thanks
    just downloaded the app on my brand new FR230.I tried to set the app but in the manage App of Garmin express I cannot find the 3 dots that should give me the possibility the change the settings.
    Here the image of my screeen: any idea what's going on?
  • Fantastic app :-), any chance of doing the same with Power zones?
    Time in Zone not showing on screen
    I downloaded the app and installed it on my Garmin 230. I have enabled the screen. But, "time in zone" data does not show up. Just my current heartrate and then a description of the level (e.g. "warmup"). I think that I might be missing a setting to enable time in zone data to appear on the screen as shown in the screen shots. Thanks.
  • suggestions
    Hello
    I would like to suggest two changes:
    - change the zone colors in a way that is more relevant to intensity
    z1: light green
    z2: dark green
    z3: light red
    z4: red
    z5: dark red
    - give the option to display time in zone in % of total time
    Thanks
    No longer working properly with Edge 520 and 7.1 firmware
    Not sure what is wrong but I can't get this to work properly with the latest 520 firmware - it worked fine on 6.x firmware. It appears as if it isn't using my max HR that I specify - even though it appears as if this value is getting set properly. The relative sizes of the zones I've specified (essentially the zones Strava uses) looks right - but the actual crossover between zones looks wrong, making me think it is improperly using some other max HR. The max HR in the "app" is set the same as what I have on the Garmin.
    Also, I've gotten lots of other apps to work with this firmware - Strava Suffer Score, MPA and Power from Xert, Edge 6, another HR app. This one just doesn't seem to want to respect the max HR I give it and it is impossible to debug what is really going on.
    Thoughts?
