Data field: Heart rate and Time in Zone
The Heart Rate and Time in Zone data field enables you to see all the relevant heart rate data in one screen.
This data field shows your current heart rate and zone in a gauge and the time spent in each zone during the current activity.
Some screen prints:
You can find the data field here: https://apps.garmin.com/en-US/apps/53505cae-a7d8-4fcb-97fa-4ad28a244d90
*********** Features ***********
- Heart Rate in beats per minute (BPM), percentage of maximum (HR %Max.) or percentage of heart rate reserve (%HRR);
- Heart Rate and Zone gauge;
- Time spent in each zone during the current activity;
- All zones are fully adjustable with the app settings editors in Garmin Express and Garmin Connect Mobile (see support);
- The default zones are 50-60, 60-70, 70-80, 80-90, 90-100 % of your HRR, with your maximum heart rate based on your age. These will be used if you don't set the app settings.
*********** Requirements ***********
Connect IQ version 1.2 or above
*********** Feedback and support ***********
If you have any feedback or if you need some support, please leave a message in this forum thread.
General information about app settings can be found here
To determine your resting heart rate, you can use my Resting Heart Rate data field.
*********** Version history ***********
v1.1:
  • Added option to choose background color;
  • Time in Zone is now shown after exercise has ended.
v1.0: Initial version
*********** Setting up the data field ***********
You can set your zones in the User Settings section of Garmin Connect Mobile or Garmin Express.The setup is the same as setting your zones in Garmin Connect, based on %HRR. Unfortunately the order in which the settings appear might be different.
If personal zones are not set, default will be set based on your age. Currently it's technically impossible to retrieve your zones directly from the device or Garmin Connect
Setting up the zones in Garmin Express (recommended)
  • Go to "Manage Apps", a list of all your apps is shown;
  • Look for the Heart Rate and Time in Zone data field and press the "..." besides the data field name, a page is shown where you can change the settings;
  • Change the settings to the appropriate values:
    • Display Heart Rate as: display the current heart rate in BPM, HR %Max. or %HRR.
    • Resting Heart Rate: fill in your resting heart rate. If set to the default of -1, it will get the value from your connect profile
    • Zone 1 %HRR: lower bound of zone 1 as % heart rate reserve (HRR). HRR is the difference between your maximum and resting heart rate. If you prefer to use HR %Max, set resting heart rate to 0.
    • Zone 2 t/m 5 %HRR: same as zone 1. Make sure that the values are incremental, because the data field will show the first zone that fits and if they are not incremental, you'll get unexpected results. If you want to use less that 5 zones, set the values of the zones that you don't use to 100. More than 5 zones is currently not supported. If you do want more, please leave a comment and I might be persueded to add more.
    • Max Heart Rate: fill in your maximum heart rate. If set to the default of -1, your maximum heart rate will be estimated based on your age
    • Background color: Choose the background color for the data field
  • Press "Save" to save the changes. The new values will automatically be send to your device.
I you want to check whether the new values are saved to your device, you can simply go to the settings page again. Garmin Express will always load the settings directly from the device.
Setting up the zones in Garmin Connect Mobile
It's possible to set up the zones in Garmin Connect Mobile (GCM), but in the current version the settings might be displayed out of order. Therefore using Garmin Express is recommended.
The following explanation is based on GCM for Android. GCM for iPhone should be (almost) the same.
  • In the menu go to "Garmin Devices";
  • Select your device from the list;
  • Select "Connect IQ Apps";
  • Select "Data Fields";
  • Select the Heart Rate and Time in Zone data field;
  • Select "Settings" (if your device does not have Connect IQ 1.2 installed, you'll get a message "An error has occurred");
  • Change the values (as described in the Setting up the zones in Garmin Express section above);
  • Select "Done" to save the values to your device
Same as with Garmin Express, you can check the settings by going to the Settings page again.
    Former Member over 9 years ago
    Display
    I installed the app, edited data fields but I cannot seem to find the display of app on my Garmin 920. I went to an exercise, like running, connected the heart monitor but it displays but not this app. How do I find it?
    It's a data field, so you have to set it as a field inside of one of your profiles. In the menu you can do that under Activity settings > Data screens. Then select the screen you want to use, set layout to 1 Field and for Field 1 select the Heart rate and Time in Zone field.
    This is super cool for runners, just added to garmin 1000.
    Time in power zones would be so much more useful for cyclists, any plans on doing it? So far no one has it, and it is crucial when training with power to see how much time you have logged in each zone. Even during race you can easily determine how much you still have left in your tank. it would be phenomenal to have both HR and Power zone son one screen.
    In out club people are buying Perfpro studio just for that single functionality on PC while training o nthe trainer, since trainer road and golden cheetah do not show it life.
  • Love this app,definitely my favorite but I can't find a way to edit my zones. From the garmin connect on my iphone I go on the setting but for some reason the connection fails everytime,is there a way I can set it up directly from my garmin 520?
    Just a little suggestion,seeing that most of us have already setted up the hart rate zones on the garmin app it would be good if your app could use those automatically
    Thanks
    Grade % data field
    Hi TeunMo, any chance to have a similar visual datafield but with the grade % data field in place of HR ?
    Waiting for you kind reply
  • Usage on Edge 1000?
    I uploaded the Heart Rate APP on my Edge 1000 but I can not see it.
    How can I have access to it?
    many thanks!
  • Freq Zone synch with Edge 1000?
    I have installed the APP on my Edge 1000. It works fine except one aspect.
    Even if I customize the Fr Zone via Garmin Express in order to have the same zone customized as in the Edge 1000, your APP doesn't save those values and therefore shows different zones. Wouldn't be possible to synchronize the APP zones with those configured in the Edge?
    many thanks!
    edge 1000
    settings from the phone can not change the data fails.
    Keep the data would be useful in the Garmin Connect with the results of the areas once the session ended .
    Please improve this good application.
    thanks
  • Values setting
    I went to "Manage Apps" to Change the settings to the appropriate values.
    I edited both the Resting Heart Rate and the maximum heart rate (the same values that I stored in the Edge 1000).
    I therefore synch with Garmin Express.
    To check whether the new values were saved to the device, after having unplugged the USB and reconnected, I went to the settings page again and I found again the Maximum and resting values at -1 (insted of the values that I had introduced).
    In addition, during a training session, I discovered that the Edge 1000 indicates a different Zone than what your APP displays. In other words it seems that your APP doesn't work with the fields values (Rest and Maximum) that have been introduced
    Am I wrong?
    what am I missing?
    Many thanks!
  • HR in absolute values
    In the current version it's only possible to use %HRR, or if you set resting heart rate to 0, you can use HR %max. If you've set your hr zone values in Garmin Connect, you can look up the corresponding percentages there. In a next version I might add an option to use the absolute values in stead of the percentages, since you're not the first to ask this. I'll put a new version in the store when Edge support has been made available (I'm not sure on the date, but it won't be long).
    TeunMo having HR as absolute value it would represent a great enhancement!
    please..... do it! Thanks!
