DIY Designer
Thanks for this great job. Can you add a possibility to have more Layout strings in the Data field settings? For example one for running, next for bike and next for others.
By Clock Time between 0:00 and 1:00 (at night) it shows only Minutes and Seconds (Zero is not appeared). Can you add the possibility to have Clock Time with HH:MM only (without Seconds).
Thank you very much.
