Watchface: Line
https://apps.garmin.com/en-US/apps/8f8adabf-8cb1-4ffd-b40e-283350d47601
Digital watch face designed by Jono Gaughan.
Watch Face contains configurable data fields:
- Time and date
- Steps count and daily goal
- Today's distance
- Notifications count
- Alarms count
- Battery status in percentage
- Calories
- Joules
Seconds are visible on gesture (in low power mode is visible just this: "--").
To activate Hi Power mode, you need to raise your hand in front of your face.
Supports 12/24 time format and km/mi.
Color configuration (requires device firmware with CIQ 1.2 or higher).
V 1.01 - added support for forerunner 920XT
V 1.02 - Fixed displaying the date (Chinese language)
V 1.03 - smoothed font for minutes
V 1.11 - Some texts were little shifted
V 2.00 - All data fields are now configurable
V 2.02 - On your wish added support for devices Fenix 3 and D2 Bravo
  • V 2.20 - you can now choose background color (black/white)
    Former Member over 9 years ago
    Hi Stanislav.Bures,
    many thanks for the white background :)
    That's great!
    Best regards, BV
    Background problems
    Hi
    The color change background in not ok on my fenix 3
    Thank you
    Move field?
    Hello! One of my favorite watch faces great job and thanks!
    Will you be able to have a "move" field available so I can see at a glance that the watch is asking me to move? Sometimes I miss or forget that I need to get up and move around.
    The concise watch face was able to fully integrate the move bar into the bottom of the screen but that would not work well with this watch face aesthetics and a little overkill. Just a field that says "move" not necessarily the number of move bars.
    Thanks again! Cheers.
  • Color
    Great watchface. Thanks a lot. while playing with the different colors I found that purple and pink show the same shade (looks pink to me actually).
    It would be great if you could add some stylish move bar
  • Sleep mode
    Hi Guy,
    Probably the best watchface for me ! Thanks a lot for doing it !
    Could it be possible to add a "sleep mode" indicator on one line ? That is for me (and for the moment) the only missing field on it...
    Thanks again
  • "Move" and "Sleep" indicator is a good idea - I am busy for now, but I will add it to next version.
  • Burn Calories
    Can I check regarding the Burn Calories.
    The reading (kCal) appear on the watch Line, Isiz show the total calories that
    I have burned since day 1? Or is calculate base on daily/weekly/monthly?
    Do kindly advise.
    Thanks.
  • Very nice watchface but I would like tu have the week distance of my favourite sport (ex. swim, run, bike, etc.) in configurable fields and the last run distance of the same sport.
    Caratteri piccoli e poco luminosi!!!
    Sure, it will not be a problem with the next version.
    La tua è l'unica Watch Faces veramente elegante e funzionale che abbia trovato nello store di Garmin.
    Detto questo, io utilizzo vivoactiv, purtoppo l'orologio è poco luminoso e con poca luce si fa fatica a leggere.
    Trovo i carattere piccolissimi, capisco che il display è piccolo, sarebbe fantastico se almeno i numeri dell'ora fossero un pochino più grandi. Sarei felicissimo di caricare il mio vivoavtive ogni 3/4 giorno pur di averlo più luminoso!!!
    Molti complimenti, sei uno sviluppatore bravissimo!!!
