Watchface: Line
https://apps.garmin.com/en-US/apps/8f8adabf-8cb1-4ffd-b40e-283350d47601
Digital watch face designed by Jono Gaughan.
Watch Face contains configurable data fields:
- Time and date
- Steps count and daily goal
- Today's distance
- Notifications count
- Alarms count
- Battery status in percentage
- Calories
- Joules
Seconds are visible on gesture (in low power mode is visible just this: "--").
To activate Hi Power mode, you need to raise your hand in front of your face.
Supports 12/24 time format and km/mi.
Color configuration (requires device firmware with CIQ 1.2 or higher).
V 1.01 - added support for forerunner 920XT
V 1.02 - Fixed displaying the date (Chinese language)
V 1.03 - smoothed font for minutes
V 1.11 - Some texts were little shifted
V 2.00 - All data fields are now configurable
V 2.02 - On your wish added support for devices Fenix 3 and D2 Bravo
    Former Member over 9 years ago
    I'm sorry if this has been asked already, but how do I edit this watch face (configurable fields) for the 920XT?
    Former Member over 8 years ago
    No weather option in settings
    Hi, Love the watch face, however cannot see the settings for the darksky api.
    Have fenix 3 HR software version 4.30 and have tried on Garmin Express version 5.4.1.0 and iOS Garmin Connect version 3.18.0.12
    Thanks for your help.
  • Hi, Love the watch face, however cannot see the settings for the darksky api.
    Fenix 3 doesn't support CIQ 2.3 which is required for background data downloads so you'll not be able to have the weather on the watchface.
  • darksky api
    Can anyone that has the weather working please confirm that the API field in the setting only requires the key, nothing else? By default the darksky web address is in that field... does the key replace it or get tagged on the end?
    Thanks
    EDIT: not to worry... turns out I needed a bit more patients, only the key is needed.
    Still not working
    Hi,
    ich got my fenix yesterday.
    everthing works great, but the weather in the lowest line shows no data.
    ich placed the Key and Only the Key in the required feld.
    Still no weather showing up...
    Please help
    Tim
  • TimMichael69 - you mention a fenix is your post and your sig shows a f3hr. The f3hr can't get the background data - it's a CIQ 1.x device and will stay a 1.x device.
    Only devices with CIQ 2.3.0 or greater can do this, (newer devices) which right now is the f5 ,f5s, f5x, chronos, 935, and probably others like the q5. (some need the beta FW, IIRC)
    If you have a f5x, you want the latest beta FW for background processes to work correctly (it works on 3.44, and 4.02 just came out and the background for watch faces works there too). With the f5x, you need to follow the instructions and not just copy the main .GCD to the proper place, but also the other parts (like sensor hub and the display driver) to the proper place, which is different directory.
    Vivoactive HR has been updated to CIQ 2.3.1, will we get the weather option?
  • Anyone get Altitude or sunrise/sunset working?
    I just get "No Data" on my 5X
    Doug
  • Chemin Richmond
    Could it be possible to get a table with color and color name here in the threat?
  • Nice watchface! Cool to have weather via Dark Sky. A few suggestions:
    - Can you please combine sunrise/sunset into single datafield showing the next event (as in your other watchfaces, like SC8)?
    - Would you consider an option to use the 'stock' font for the time (or at least the same font as the other datafield a)?
    - Woud you also consider adding a datafield option that shows the time of the next calendar event?
    Thanks for considering
