If you have any suggestions or problems please post it here.
Download:
https://apps.garmin.com/pl-PL/apps/4db3d6ae-569b-4435-a7a2-67a2978c04f0
Download:
Hi there. I would like to thank you for your work and could you please add one more thing in there. I need a weather information so I will appreciate it. Thanks one more time. Best regards
Hi, how can i put colon between the date?
I also would like to have the current temperature as an option to display.
Make sure you have turned on activity tracking and in the watch face settings you have chosen steps in data field 1 or 2.
Hello great watch face loads of data selections.
Only down fall Im not keen on. The heart rate is not consistent it up dates now and then so it not a true reading.
Like the Garmin faces they consistently change HR.
If this could be changed would be ideal.
Hi, I lost the "Next sun event" from display after a FW update to v4.60. Now only two "-" is shown.
I have tried to replace the field with another data field and then back to Sun event. No luck.
Next sun event is showing fine on another watchface.
Watch: Vivoactive 4, FW 4.60 (just got FW4.70, but still not working)
Go outside and start an activity with GPS
Go to an activity (running for example) wait for GPS fix and then go back to watch face. It should help.
Hi I love the watch face. Seems to be a small bug in latest version on va3. Every time the watch face shows up (i.e. after swiping to a widget) the step count will be positioned to the left for about a second before it jumps to Its correct position in the center.
Thank you for the feedback.
I'll try to fix it in the next update.
